Cambelt change interval depends on spec?
Hi! Heard about every 10 - 20K miles on high powered engines. How do you handle it? Is there a standard value? Would never neglect this item but it's interesting to know.
I changed the timing belt on my wifes 1.6 focus 2 weeks ago.The car has 95k on it and the belt look as if it had only been fitted a year or so ago.It still had the writing on it.
The belt and tensioner isn't expensive, thats right, but if you add the costs for the fitting it is a difference between every 10 or 50K.......
Thanks for the answers so far.
Anymore?
The wear of a timing belt depends on more factors. Had ask some motorsport companys. For example worn teeth on camshaft gear wheel will quickens the wear on a timing belt and some more points .... it was interesting to know, have to read the rest.
