Mk1 focus rs rod bolts
Old Oct 8, 2012 | 07:28 PM
rhinopower's Avatar
rhinopower
Default Mk1 focus rs rod bolts
Can these be reused, and to what torque, or need replacing with 8/9mm zetec arp's?
Old Oct 8, 2012 | 08:44 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Personally I'd only ever re use the arp bolts mate
Old Oct 8, 2012 | 08:55 PM
rhinopower's Avatar
rhinopower
Il order a set. Same as normal black tops, 9mm?
Old Oct 8, 2012 | 08:57 PM
Dicko&Vacant
I'm not sure mate, I noticed on ebay they do different sizes? Mine already had the arp's fitted
Old Oct 8, 2012 | 09:35 PM
Churtz's Avatar
Churtz
There's no fact to say that blacktops or silvertops have 8mm or 9mm. It seems they are just random selection. My focus rs lump has 8mm, but an old blacktop lump I had was 9mm. Bizzare when u consider the focus rs mk1 lump is essentially a blacktop. You'll need to whip a rod bolt out and check.
Matt
Old Oct 8, 2012 | 11:29 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
There is no rule as to how many times an ARP fastening can be reused. The bolt stretch needs to be accurately measured to determine whether it is achieving suitable tensile load or not. If it has 'stretched' excessively then it will go beyond it's yield point and be at risk of failure under high engine speeds or loads.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Fordmad!
Sep 4, 2015 01:42 PM
salsheikh
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
