Moondust Fiesta Track car build
Old Oct 6, 2012 | 08:33 PM
Mr Kro's Avatar
Mr Kro
Default Moondust Fiesta Track car build
After some time away from Fords ive taken the plunge and bought myself a rolling shell, my 2nd Moondust Mk5. It was bought from a long standing member off a Fiesta forum
The shell itself is in great condition, very minimal rust on the bodywork. A bonus also is that it has a Rose jointed rear beam. The plan is to build it up over the coming months (No real time limit tbh), and turn it into a track car. But also in mind to drive to shows/meets etc.
As it stands (Most of the items i have but arnt actually on the car as such)
Interior
Lightend dash
Sparco buckets
4 point harnesses
OMP Corsica wheel (Very flexible)
OMP 10 point cage
Exterior
Standard
Suspension/tires
Compomotive TH's
Toyo R888's
Gaz coilovers
FRP Alcon brakes
Ford Focus ST170 disc's
Area six rose jointed lower arms
Engine
2.0 Zetec Blacktop with an ST170 Head
Newman cams
gsxr ITB's with Manifold to suit
Custom exhaust manifold
Once the car was parked up i went over it with a sponge and brush just to get rid of the grime and moss that had built up of the previous year or so. Looks alot better than i thought it ever would
Old Oct 6, 2012 | 08:40 PM
Mr Kro's Avatar
Mr Kro
I then picked up another shell. It is fairly tidy but not as good as the Silver shell i have.
I bought it because it has a few parts that i wanted the parts off it.
Alcon FRP 4 pot brakes
FRS rear disc conversion
OMP 10 point cage
Gaz coilovers
The car was then gutted and ended up as a big lump of scrap
Pictures of the cage
The 3 minute door removal technique
How the car now looks after 2 hours. Who needs axle stands when you have wheels and bricks
Old Oct 6, 2012 | 08:42 PM
Mr Kro's Avatar
Mr Kro
Pictures of the parts taken off the car
Focus RS front discs with Alcon 4-pot Calipers
ST170 rear brake conversion
Gaz coilovers & Nissan 200 top mounts
Area Six rose jointed lower arms
Old Oct 6, 2012 | 08:45 PM
Mr Kro's Avatar
Mr Kro
Nothing major, just fitted the front coilovers, lower arms and rear coilovers
Im not bothered about height atm, i just wanted it off the axle stands
Old Oct 6, 2012 | 08:49 PM
Mr Kro's Avatar
Mr Kro
Then in order to get the cage out with minimal hassle the roof was cut off the blue Fiesta
Old Oct 6, 2012 | 08:53 PM
AJC's Avatar
AJC
Good going. Where in Blackpool are you?
Old Oct 6, 2012 | 08:55 PM
mothrs2k's Avatar
mothrs2k
Lookin good fella, be a nice track car when its done
Old Oct 6, 2012 | 09:00 PM
Mr Kro's Avatar
Mr Kro
I then decided to change the 330mm FRS front discs for 300mm ST170's, this still meant that i needed a bigger set of wheels. I ended up buying these Compomotive TH's (Already came in green) and they also came with Toyo R888's (Only done one a morning's trackday)
Old Oct 6, 2012 | 09:02 PM
Mr Kro's Avatar
Mr Kro
Cheers pal, i live in Thornton, just outside Fleetwood & Cleveleys
Cheers pal, not a million miles away now.
Old Oct 6, 2012 | 09:08 PM
Mr Kro's Avatar
Mr Kro
I bought a few bits and bobs a couple of weeks ago and today was the first day that i have been to the car to have a look. ST170 Head (VCT removed and was fully rebuilt not long before it was taken off), Newman Cams (Fairly aggressive), Custom exhaust manifold, gsxr bike bodies with inlet manifold to suit and linkages.
Ok, so finally got a little closer today. Found a 2.0 Blacktop from a Focus and a gearbox from a diesel Focus. Had a little mock fit up of the bottom end, ST170 head and gearbox. The gearbox mount didn't quite line up so i think i Zetec s one would fit.
2.0 Blacktop
Focus diesel gearbox
Removing the head
Cams removed
Block and gearbox mock fitted
ST170 head
Fitted to the block
Removed Aircon pump
Old Oct 6, 2012 | 09:12 PM
Mr Kro's Avatar
Mr Kro
2.0 Blacktop inlet ports
ST170 inlet ports (Notice the difference in size)
gsxr Bike Bodies
Inlet to suit
Newman Cams
Verniers
Old Oct 6, 2012 | 10:08 PM
mothrs2k's Avatar
mothrs2k
Who ported your ST head pal?? The ports look all diffrent shapes and sizes to me
Old Oct 8, 2012 | 12:06 PM
Mr Kro's Avatar
Mr Kro
I used a Brillo pad to shape them
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
RIB1122
Aug 3, 2015 09:20 AM
