stripping a moonstone blue 4x4 saph, lots of parts avalable
i am building up a rwd saph using a new shell and trim.
i am using all parts found in the bay,exsorst,brakes,fule pump and ecu. so if you need out else then let me no, off hand hear is some parts avalable off hand.
both diffs
mt75 box
rack
hubs
front brakes
props
drive shafts
bumpers
grill
petol tank, was new 2 years ago
new starter motor less than 1000 miles old
the car will start to be stripped on sunday the 21st and should take a max of 2 weeks. if you have any questions just ask and make sensible offers for parts.
both diffs
mt75 box
rack
hubs
front brakes
props
drive shafts
bumpers
grill
Interested in the front prop, fuel tank strap, little clip that holds the glovebox in place and the gear lever surround that holds the electric window switches in (if all clips intact)
Many thanks
James
Many thanks
James
track.focus'd
Aug 12, 2015 05:53 PM
