MT75 4x4 Gearbox centre diff drive split
Old Oct 4, 2012 | 08:41 PM
Rufusw5's Avatar
Rufusw5
Smile MT75 4x4 Gearbox centre diff drive split
Hello All,
Hopefully someone has an answer for this.... I'm building a rear engined 4x4 project, the engine needs to be longditudionally mounted.
My plan is to use an MT75 Xr4x4 gearbox, my issue is that this box splits the drive 66/33 R/F or so I'm led to believe, that leaves me with an actual drive split of 33/66 R/F which will cause more problems that it's worth.
What i would like is the standard 66/33 split going the right way (So backwards for the gearbox) but if I can't get that then a 50/50 split would be a compromise.
Can someone tell me if its possible to flip the centre diff? If not, anyone know what parts are available for this box?
I'm not expecting this to be a cheap project but would rather it didn't get stupidly expensive..
Before anyone comments on the front / rear diff drive direction, I've more or less solved that, either way it's a different issue and would rather keep the discussion here on getting the right F/R drive split from the MT75.
All advice is appreciated!
Old Oct 7, 2012 | 12:24 PM
markk's Avatar
markk
No you cannot change the diff output, though you can buy planetaries to give you a 50/50, but they are rare.
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
