£800 shock absorbers
Old Sep 29, 2012 | 02:17 PM
Blown Hell's Avatar
Blown Hell
Default £800 shock absorbers
Just picked up my 55 Mondeo 2.2 tdci Estate from the garage- serviced & MOT'd.
The problem is one rear shock is starting to leek the mechanic pointed this out to me and said it/they will need replacing soon, price £310 each plus VAT!!! apparently they are self leveling. My question is this; is it possible to fit standard shocks or do I need to change the springs aswel? as this would be the much cheaper option.
Old Sep 29, 2012 | 05:06 PM
Cosnada's Avatar
Cosnada
You can swap out the self levelers for standards and yes you have to fit new standard springs to match. The standard springs are much stiffer.
You can replace both springs and shocks for less than the price of replacing one self leveling unit.
If ya not sure I'm Sudbury way and can convert it over if you. Give me a PM
Old Sep 30, 2012 | 08:29 AM
Blown Hell's Avatar
Blown Hell
Thanks for that Cosnada I wasn't sure you needed to change the springs aswel, it's deffinately gona be cheaper!
Old Aug 31, 2013 | 09:18 AM
ESCORT-NUT-2012's Avatar
ESCORT-NUT-2012
is it the same on a mk4?
Old Aug 31, 2013 | 01:33 PM
bookwyse's Avatar
bookwyse
Same on the Mk4 however you have to be careful as the self levelling system also contains the sensors for the auto head light adjust and changing them can cause errors in that system.
155lee
Oct 24, 2015 11:11 AM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
L1AM_RS
Sep 23, 2015 03:27 PM
