st200 power
Hi people
my st200 has a slight problem were she give 75% power or full power she chops and changes alot between the two.
need some advice/info as to fix it.
has anyone else had this with there st200.
shes std apart from mongoose exhaust system.
hope you can help
hope you can help
Does it happen when it's hot? The IMRC can play up as it's mounted just above the exhaust manifold. It's the black box that sits under the plastic shield in the engine (the one that says ST200 on it)
You can either just get a replacement one, or better still move it so it sits under the battery tray. You can get away with moving it without having to alter anything as the wiring will just about stretch that far. It's wiser to lengthen the wires though, and there aren't many so it's not a hard task.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
