Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
are there viton stem seals available for the rs2000
Old Sep 26, 2012 | 08:39 PM
turbo1's Avatar
turbo1
Default are there viton stem seals available for the rs2000
has any one used viton valve stem seals for the rs2000 if so where can i purchase them from in the uk, are viton better than standard
whats the width of the stems on the valves and are the exhaust and inlet side stem seals the same
Old Sep 26, 2012 | 10:41 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Pretty much all valve stem seals will be viton as nothing else will take the temperatures.
Old Sep 27, 2012 | 09:32 AM
turbo1's Avatar
turbo1
The genuine items from ford are these viton may as well go purchase them
Are the inlet and exhaust side the same size
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
krypton
Sep 23, 2015 07:29 PM
