st engine in a sierra?
Old Sep 24, 2012 | 08:22 AM
Gary H's Avatar
Gary H
Default st engine in a sierra?
Hi, I was wondering if anyone knows of or tried to fit a 2.5 5cyl turbo engine from a focus st into a 2wd sierra??
And would it be worth any less if I did this, its a proper low milage cossie but finding an old yb engine gets harder and harder
Thanks for any advice and comments
Old Sep 24, 2012 | 08:45 AM
dojj's Avatar
dojj
Resident Wrestling Legend
You need to custom fabricate the mounts and they need to be fairly long
Been there done that and it's a pain in the arse but would be worth doing if you've got the time and the fab skills to do it
I got bored and then got rid of the sierra it it all fits, I measured it all up and it's doable
Old Sep 24, 2012 | 09:17 AM
Gary H's Avatar
Gary H
Sound, what gearbox did you use? Fabrication isnt too much of a worry for me fortunatly but I don't want to make the car worthless by doing it
Old Sep 24, 2012 | 09:39 AM
dojj's Avatar
dojj
When it meant a lot of work to make Ho the engine mounts I sort of quit while I was behind
If you look at the bare block you will see that there are virtually no points along its length to stick any mounts on either side do you are left with tieing into either end or using the intermediate cross shaft mount or the actual exhaust mounts or the from end somewhere
The front of the engine has 2 knock sensors screwed to it as well so if you turn it through 90 degrees and make it onto the drivers side you've got to think about where the rack is going to go as well as the sump sits very low and the bowl is not just at the front but at the back as well as the whole thing is designed to be slotted in from underneath
Not an issue on a front wheel drive car but a right pain in the arse for turning it sideways
That said, there are plenty of Volvo peeps who will have done a rwd conversion so maybe scouting about on their forums would be an idea
Old Sep 24, 2012 | 10:35 AM
Gary H's Avatar
Gary H
I must be crazy for thinking it then lol but what a car it'd be eh :-D
Old Sep 24, 2012 | 06:33 PM
dojj's Avatar
dojj
if you've got the time and the engine and the shell give it a go, it might be hard but at least it'll be different
Old Sep 24, 2012 | 11:13 PM
wattie's Avatar
wattie
There's a restro thread on here with a guy fitting a focus st engine into a 100e pop he managed to fit it with a little thought so the bigger sierra shouldn't be a problem if you've got the skills
Old Sep 25, 2012 | 07:51 AM
Gary H's Avatar
Gary H
Needs some thought, lol. I won't do anything without thinking it through and solving the problems in my head first. :-D
Old Sep 25, 2012 | 02:35 PM
Gary H's Avatar
Gary H
I'll have to check it out,
Anyone know what box fits the st engine?
Old Sep 25, 2012 | 03:16 PM
XRT_si's Avatar
XRT_si
No Ford 'box bolts up unless you make an adaptor plate:
https://passionford.com/forum/restor...s-of-pics.html
Old Sep 25, 2012 | 09:04 PM
caprizetec170's Avatar
caprizetec170
sounds good idea was going try same in capri but got lazy and stuck zetec in it. do bit research and you'll probably find a volve box and sump to fit
Old Sep 26, 2012 | 10:18 AM
Gary H's Avatar
Gary H
I think I've come up with a way around the sump/subframe clearance issue and incorporating places for the sierra mounts to fit too.
Just need to get my hands on a engine for an hour for inspection
SmudgerByName
52
Jul 28, 2016 06:14 PM
Toms Grende
13
Aug 22, 2015 03:39 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
