hi or low imp injectors
hi ive got a dta p8pro and i dont know which injectors it should run . hi or low imp . it has run focus st170 ones for 10months fine but also run bosh 403 grey for 2 years. i cant see a ballast resister so why is it working with both and what damage could /has it done to the ecu im thinking it should run 5ohms or more which i thought was hi imp injector . correct me if im wrong.
You should really run high impedance injectors, if it still running ok I don't think you've one ny damage to the injector driver circuit. Low impedance injectors will demand more current.
Get some high in there ASAP,
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
