Escort mk2 projekt
Old Sep 14, 2012 | 09:09 PM
Svenne's Avatar
Svenne
Default Escort mk2 projekt
Car: Escort mk2 1975
Engine: 200 block, 10 x longstud, oil-jets, 91.50 JE-pistons, ballanced fly & crank, vev, 6 kg flyweel, 24/26 mm ported topp, lovered springseat and valve-guides, PiperCams springs, Solid lightweights folowers , ZL-14 in and exh cams, 3-stage drysump oil system, Pace tank i trunk, special inlet manifold, 1680 cc injectors, 2 x 044 fuelpumps, Autronic fuel management, Garret GTX3076R, Stainless steel exhose 42,4 mm., Tial wastegate, mapped to 455bhp at 17,4 psi. Shell go E85 next year with heavy boost.
Chassi: Volvo 1031 3,54:1 rear axel with Torsén diff 4 link and Wattlink, mt-75 gearbox, Cosworth breaks with Rallydesigne break pedal box, 8,5 x 17" weels,
You can see pictures here: http://www.fordclubsweden.se/forum/s...=15941&page=11
Old Sep 15, 2012 | 05:47 PM
katluke's Avatar
katluke
Did you also use a Volvo steering rack and column ? Car looks well
Old Sep 15, 2012 | 08:51 PM
andy escos's Avatar
andy escos
very nice where did you get the oval to round pipe from manifold profile to round tube .
Old Sep 16, 2012 | 04:49 PM
Stunning car.
Old Sep 16, 2012 | 07:03 PM
Svenne's Avatar
Svenne
Hi there...
No Volvo steering, build litle like classic Grp 4 with Capri HD legs, M55x2 screw/nut, 60 mm springs and short mk2 steering.
//Patrik
Old Sep 16, 2012 | 07:13 PM
Svenne's Avatar
Svenne
Hi there...
Those i did myself from 50 mm pipe first squeezed them to ovals and then in a hydralic hose press in tre stage in to 42,40mm outside dia. Can make some if you need.
//Patrik
Old Sep 16, 2012 | 08:51 PM
gjh's Avatar
gjh
Great looking car there
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
