Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
225 with de-cat fitted?
Old Sep 14, 2012 | 07:58 PM
LIMITLESS's Avatar
LIMITLESS
Default 225 with de-cat fitted?
Im thinking of fitting a decat to my Mountune 260 st, is there any way of stopping the EML light coming on when using a de-cat?
Old Sep 14, 2012 | 08:31 PM
Carlos-Titx's Avatar
Carlos-Titx
You need a spacer mate.
http://www.just-performance.co.uk/o2...xtender-de-cat
Old Sep 14, 2012 | 08:35 PM
LIMITLESS's Avatar
LIMITLESS
Carlos mate, is this really all ill need as the seller has told me ill need a Scc map as its the only map that will stop the light from coming on ?
This spacer seems like the idle way to go for me
Old Sep 14, 2012 | 08:48 PM
Carlos-Titx
Can't say first hand mate but this was the route I was goin to go when I had mine, heard it does work.
Or buy a cheap fault code reader and clear the codes each time it comes on. Gets annoying though.
Old Sep 14, 2012 | 08:53 PM
LIMITLESS's Avatar
LIMITLESS
I have a found a cheap mongoose de cat for sale so I might just get it and try, whats the worse that can happen!
Old Sep 14, 2012 | 08:55 PM
Carlos-Titx
It's worth a shot. Or just tape
over the light lol.
Old Sep 14, 2012 | 09:13 PM
LIMITLESS's Avatar
LIMITLESS
over the light lol.
I think it is worth a shot mate,
Old Sep 14, 2012 | 10:23 PM
Karl 3dr's Avatar
Karl 3dr
I've been told to steer clear of the extension things cos they move the sensor further out and the sensor then doesn't read right, meaning it could go lean etc. Meant to sound awesome though lol
Old Sep 20, 2012 | 06:00 PM
James's Avatar
James
something i read on another forum a few weeks and it made me wonder.. When you have decat fitted the extra heat in the exhaust system means you destroy silencers quicker ?
Any thoughts?
Old Sep 20, 2012 | 07:25 PM
Carlos-Titx
It's not going to be reading right with no cat anyway, but moving the sensor will put its readings closer to what they should be as they eml light ain't on.
That's my thinking of it which of course can easily be wrong.
Old Sep 20, 2012 | 07:26 PM
Carlos-Titx
James, not a clue. Never heard of that one before.
Old Oct 2, 2012 | 08:43 PM
duncans90's Avatar
duncans90
The bit about the maps is rubbish, most off the shelf maps such as Dreamscience etc will turn the light out providing you have a sensor fitted. If your not planning on mapping the car with the decay then a sensor spacer is a perfectly acceptable way of doing things.
Old Oct 2, 2012 | 08:50 PM
Carlos-Titx
Off the shelf maps don't turn the light off.
Old Oct 2, 2012 | 08:58 PM
duncans90's Avatar
duncans90
My Dreamscience turned it off when I had it on that map
Old Oct 2, 2012 | 09:08 PM
RichieST's Avatar
RichieST
I've got a sports cat on mine at the mo and am thinking about doing it the pikey way by smashing the internals out of the standard cat and putting that back on for a bit just to see what it's like!
Carlos-Titx
You can turn the light off but it will come back on again. Unless you have that off the shelf map tweaked to perminantly keep the eml off for the cat fault code.
I had to keep plugging my DS in and turn it off but it would come back on again. Varied as to when it came back on. Sometimes a few hundred mile some times 1000 mile.
Old Oct 2, 2012 | 09:11 PM
Carlos-Titx
Sell the standard cat and buy a decat. Seen standard cats at Ł150 + on fleabay used. Ł70 for a decat. Win win.
Old Oct 2, 2012 | 09:17 PM
RichieST's Avatar
RichieST
I've just had a look, seen on completed listings though that they don't seem to sell at that price. I might just start it at 70, if it sells i'll buy a decat pipe, if not then it gets it
Old Oct 2, 2012 | 09:20 PM
Carlos-Titx
I didn't look that far into it. Only looked as mrs tripped up over it in the spare room, had a look and thought that would get me fair few bottles of vodka then left it in te spare room ready for the mrs to trip up over it again.
Old Oct 3, 2012 | 05:56 AM
RichieST's Avatar
RichieST
mean bastard
Old Oct 6, 2012 | 09:32 PM
RichieST's Avatar
RichieST
Just ordered a de-cat. Don't tell my mrs or she'll rip my fucking bollocks off
Old Oct 6, 2012 | 09:44 PM
Carlos-Titx
I won't ring her to tell her what you have done from my relegated bed that is the couch!
Kyle Langford
27
Aug 5, 2019 07:54 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
