Remote Brake Adjuster Help
Hi Brian,
You need an adapter to grub screw the cable end into that locks onto the end of the balance bar...
Dependant on manufacturer the balance bar could be M10 x 1, 3/8x24 unf or 7/16x20 unf...
You'd need to check with a thread gauge...
HTH
Ian
You can see it on the left hand side of this balance bar
This is the sort of thing available fro OBD...
http://www.rallynuts.com/motorsport-...e-adaptor.html
HTH
Ian
HTH
Ian
HTH
Ian
