cosworth arp torque settings
Old Sep 12, 2012 | 11:42 AM
gingerdom18's Avatar
gingerdom18
Smile cosworth arp torque settings
hi ive got a arp stud set and a wrc spec steal headgasket. any one know the torque.settings? cheers
Old Sep 13, 2012 | 10:02 AM
gingerdom18
surly some one must have an idea?
Old Sep 13, 2012 | 11:07 AM
andy escos's Avatar
andy escos
here you go copied from another user on here
Garage is empty, add now
Trader Score: (4)
this is copied from the instructions you get with the arp kit, although i left mine overnight and then rechecked and retorqued as needed
1) To ensure proper thread engaement and accurate torque readings,
clean and re - tap, if necessary, ALL threads in the block.
2) Clean and insoect all hardware proir to installation. Look for obvious
defects or shipping damages, plus proper fit, length and dimension.
3) a. If cylinder head studs protude into water jacket, lubricate the block
threads of the studs with ARP THREAD SEALER.
b. If cylinder head studs protrude into blind hole, lubricate the threads,
nuts and washers with ARP THREAD LUBRICANT or 30wt oil.
c. Screw studs into block "HAND TIGHT ONLY" .
NOTE: LOCTITE MAY BE USEED IF A PERMANENT MOUNTING OF THE
STUDS IS PREFERRED. THE FASTENERS, HOWEVER MUST BE
TORQUED PRIOR TO THE LOCTITE SETTING UP.
4) Intsall cylinder heads and check for binding or misalignment.
5) ARP recommends using the ARP MOLY LUBRICANT or at the very least,
a good quality Moly Lubricant as opposed to motor oil. this is due to
higher friction on the studs aswell as inconsistances in the clamping
force of the fastners when moto oil ( or low quality lubricant) is used.
PRELOAD (TORQUE) RECOMMENDATIONS:
Torque values are based on 75% of fastners yield strength. Use the manufactuers torque sequence but do not use the engine manufacturers torque specs.
Torque the nuts to 81ft lbs for ARP MOLY ASSEMBLY LUBRICANT
( or thread sealer) or torque to 105 ft lbs with 30 wt motor oil.
__________________
here is the thread
https://passionford.com/forum/ford-s...ts-torque.html
the only thing i will add is do not get carried away as it has been known to rip the threads out of the block .
hth Andy
Old Sep 16, 2012 | 08:49 PM
costina's Avatar
costina
Live long and prosper!!
I would never use these again they cracked my 205 block... use either std head bolts or proper long stud kits which can only be used on 200 blocks.
A well respected tuner on here said theres 17 thou of expansion and contaction of a yb head so you would always be torquing the head up..
Oct 9, 2015 07:38 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Aug 14, 2015 07:29 AM
