Acceptable gt30 shaft play with vid
Old Sep 11, 2012 | 04:32 PM
M K's Avatar
M K
Default Acceptable gt30 shaft play with vid
Is a little play in this gt3076r acceptable? the blades do not contact the housing at all, it spins well and free and it has about 1mm of play in & out
quick vid
Thanks
Marc
Old Sep 11, 2012 | 04:40 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Mine was just the same, no smoke or other noises etc. I was very dubious at first, but after reading on Garrett site, it is normal so oil can cushion the pressure when thrusting.
Old Sep 11, 2012 | 05:02 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Perfectly normal for a GT core, I wouldn't keep spinning it like that though without some oil in the core
Old Sep 11, 2012 | 05:09 PM
M K's Avatar
M K
Thanks guys, thats what i was hoping to hear
Just got to wait for the bloke i bought it from to send me an 82 rear housing now as he said it was an 82 and when it turned up it is clearly a 63 genuine mistake but now i need an 82 housing with 4 bolt pattern
Old Sep 11, 2012 | 05:20 PM
vaughant's Avatar
vaughant
Looks fine to me,when it went on my merc (gt vnt turbo) you could move it up and down about 10mm!!!!
Old Sep 12, 2012 | 12:53 PM
M K's Avatar
M K
Someone else has the opinion the there should be no in/out play whatsoever in the gt series so it seems there is a split opinion about this???
Old Sep 12, 2012 | 04:33 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
this is the info i used to justify running mine, which has about the same play as yours, all to do with hydrodynamic damping.
http://www.turbobygarrett.com/turbobygarrett/faq
not sure if that accounts for all play, but had mine on for 500miles since i bought it from clarke and no smoke or noises.
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
Rsmat
63
Sep 25, 2015 12:11 PM
rsstav
Sep 7, 2015 04:43 AM
