Some electrical questions mk4 escort
Old Sep 10, 2012 | 06:52 PM
base190380's Avatar
base190380
Default Some electrical questions mk4 escort
Hi there I have just bought another mk4 escort however it does not have the time adjustable wiper switch. Can I swap it from my first car or is there more to it than that eg relays and extra wiring
Also the fuel computer is the wiring plug there for it if I swapped that over too or is the loom different. I know I would also need to fit the speedo cable sender unit too but again is there somewhere on the loom ready for it
Old Sep 11, 2012 | 08:58 AM
iansoutham's Avatar
iansoutham
OCD Victim
Find the wiper relay and run a wire from the centre pin location in the relay block to the spare pin hole in the wiper switch plug (top corner if I remember). Then fit the switch and intermitant relay and you should be away.
Old Sep 11, 2012 | 09:00 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
It depends what car you bought and what loom it has?
Old Sep 11, 2012 | 12:09 PM
base190380's Avatar
base190380
sorry folks they are both mk4 ghia models 1.6 i
ones a later g reg car and the other i want to fit parts too is a f reg ghia
was hoping it was just a case of simple swap of switch
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
