Ford KA Discuss your Ford KA here!
Engine stopping when driving and now not starting anymore
Old Sep 7, 2012 | 07:36 AM
KaRouge's Avatar
KaRouge
Default Engine stopping when driving and now not starting anymore
Hi,
My 1999 Ka 1.3 engine stopped 3 times when driving :
1st time it stopped, i restarted it and everything was ok
2nd time i had to wait lets say 15 min and i restarted it
3rd time it never restarted, and pushed my Ka back home .
It just stop, no noise, no smoke, just a sensation of lost of engine power and stop.
The fuel pump is starting when i turn the key, the starter makes a "normal" starter noise.
Sorry for my english, especialy tecnical one, it's not my native language...
Any idea ???
Thanks
Old Sep 7, 2012 | 08:03 AM
bigkevin's Avatar
bigkevin
head gasket? check oil and water for signs of mixing
Old Sep 7, 2012 | 12:19 PM
KaRouge's Avatar
KaRouge
I've looked at the water container and nothing special only water liquid, moreover, i've changed the engine oil and the oil filter (ŕ few days before the failure happens in fact...) and didn't notice anything. I've also changed the fuel filter.
Thanks
Old Sep 16, 2012 | 07:52 PM
stu93's Avatar
stu93
My girlfriend had the same problem.
Unbolt the idler control valve on the side of the throttle body (i think was 2 8mm or 10mm bolts holding it on and an electrical connector) and give that a clean out with carburettor cleaner.
my girlfriend had the symptoms of driving and when coasting the engine just lost power
hope it helps
Old Sep 17, 2012 | 05:13 AM
KaRouge's Avatar
KaRouge
Thanks,
I',ve already clean it. I've also changed the sparks, the electrical wiring (sparks to ignition coil) and the ignition coil itself and it doesn't start anyway. It's like the car was out of gas, nothing but the starter...
Old Sep 17, 2012 | 06:33 AM
stu93's Avatar
stu93
So what happens now the starter motor doesn't spin the flywheel it is just clicking?
Old Sep 17, 2012 | 07:10 AM
KaRouge's Avatar
KaRouge
The starter is doing a normal starter noise (it's almost new, changed 3 years ago). As i said, it's like there was no gas going to the motor (but the gas pump is doing a normal start noise when i turn the key).
Old Sep 22, 2012 | 05:27 PM
mgtkr1's Avatar
mgtkr1
sounds like a hall sensor/dizzy issue. upnplug black sensor on dizzy and clean thoroughly and try from there.
Old Oct 2, 2012 | 02:02 PM
Shonky's Avatar
Shonky
V6 Ka of Love
You've change the leads but does each plug spark? Remove spark plug 1, plug the ignition lead onto the spark plug, with a pliers hold the spark plug near the engine while someone tries to start the car to see if it sparks
If it doesn't spark and you've changed your plugs and leads then change the coilpack which is under the inlet manifold
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
