oil pump
Old Sep 6, 2012 | 01:39 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default oil pump
Does anybody know if ford still sell focus rs/ 2.0 black top oil pumps? If not what are other people using?
Old Sep 6, 2012 | 07:12 PM
nevsrevs's Avatar
nevsrevs
Yea they are still available, but I would rather have a good used 1.
Old Sep 6, 2012 | 07:46 PM
Dicko&Vacant
Why what's up with new ones mate?
Old Sep 6, 2012 | 10:20 PM
nevsrevs's Avatar
nevsrevs
They started using sintered metals in new oil pump, that is not as strong as the older post 2002 gears, so we always find good condition used pumps give them a clean, check prv for play, unless planning on using it on a bogo engine, in that case forget the above?
Old Sep 6, 2012 | 10:30 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
im on a standard blacktop pump, stripped it and cleaned it, all was good so back together and handling my gt3071 well, no issues with pressure and better than a copy or ford replacement one.
Old Sep 7, 2012 | 08:29 AM
Dicko&Vacant
Think I'll get mind stripped body checked then.
Old Sep 7, 2012 | 05:35 PM
nevsrevs's Avatar
nevsrevs
That's the best route imo
Old Sep 7, 2012 | 06:08 PM
Dicko&Vacant
Got a 40k mile spare one coming tomorrow, so will strip and check it. Also just spoke to Ian Howell and he confirms my oil pressure is to low
Old Sep 7, 2012 | 07:11 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
how low is too low?
my idle is about 30psi and goes well into 80psi+ on power.
Old Sep 7, 2012 | 07:16 PM
nevsrevs's Avatar
nevsrevs
Did Ian tell you about what we have been doing to our oil pumps?
Old Sep 7, 2012 | 07:27 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
tell me what you've been doing lol!
Old Sep 7, 2012 | 07:47 PM
nevsrevs's Avatar
nevsrevs
Nothing that exciting, just started shiming the prv springs to up the pressure a wee bit, it's been working a treat, plus as you prob know polish the fuck out the plunger as they have a habit of jamming open.
Old Sep 7, 2012 | 08:24 PM
Dicko&Vacant
Originally Posted by xr2wishy
how low is too low?
Mines down to about 1 bar on idle when warm
Old Sep 7, 2012 | 08:52 PM
nevsrevs's Avatar
nevsrevs
Probs a weak prv spring, or sticky plunger
Old Sep 7, 2012 | 08:56 PM
Dicko&Vacant
Is that fixable? It's just under 6 bar from start up
Old Sep 7, 2012 | 08:58 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
6BAR at cold isn't a problem, 1BAR on idle is an issue though.
2BAR idle is common on Zetec's at idle when warm.
Old Sep 7, 2012 | 09:16 PM
nevsrevs's Avatar
nevsrevs
Just get the new/2nd hand strip it, clean and check then refit, job jobbed
Old Sep 7, 2012 | 09:45 PM
Dicko&Vacant
Cool cheers lads
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
