Routing braided lines (pic request)
Old Sep 5, 2012 | 08:42 PM
saph_Al's Avatar
saph_Al
Default Routing braided lines (pic request)
I'll be fitting my braided fuel lines next week . I have some -6 separators which i'll be drilling out to M6 and fitting longer stainless bolts through into rivnuts in the original mounting brackets . I think this should hold it tightly and also look quite pleasing to the eye . However i'm a little concerned about the route they have to take and how close they are to freshly painted items . Theres some very tight bends and odd angles which i don't like .So how has everyone else done it , Anyone have pics the pipes over the beam and onto the floor area ? .Also how you've routed for the return .I'm looking at going thought the cradle for a direct line of sight to the return . Then engine bay wise how do you get on with securing them or not as the case may be . I was just going to use the separators to keep them from flapping in the wind . any pics would be a great help . Ta muchley
Old Sep 5, 2012 | 10:33 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I did mine not long ago and it was an easy job! Mines in teflon and the pipe bent easy round the beam! but mine is -8 feed but -6 return also mine is on p clips riveted to the original clip mounts
Old Sep 6, 2012 | 06:12 AM
Ade500's Avatar
Ade500
Fixing Fords
Like this on mine
I did as you said mounting the separator clips to the floor.
Old Sep 6, 2012 | 11:39 AM
richard caine's Avatar
richard caine
rs enthusiast
Old Sep 6, 2012 | 08:59 PM
saph_Al's Avatar
saph_Al
Very nice setup's chaps thanks for the piccy's think i have it sussed , I'll stick some pics of my attempt up next week when i's done
Old Sep 7, 2012 | 06:35 PM
scott-cos's Avatar
scott-cos
nice pics. im away to do this with my esc cos. where did you get the fuel pipe from and how much was needed and cost. also need aeroquip fittings. what did you use for the breather pipe.
thanks scott
Old Sep 7, 2012 | 06:53 PM
ajamesc's Avatar
ajamesc
thanks scott
My hose and fittings all came from torques and you need about 4 meters to go from front to back
Old Sep 7, 2012 | 07:33 PM
Ade500's Avatar
Ade500
Fixing Fords
Same as you mate^^^
Old Sep 8, 2012 | 11:31 AM
scott-cos's Avatar
scott-cos
ok thanks. do they have a website. how much roughly did it cost.
thanks scott
Old Sep 8, 2012 | 12:02 PM
Sonic Boom's Avatar
Sonic Boom
Here's mine:
Rich
Old Sep 8, 2012 | 06:56 PM
saph_Al's Avatar
saph_Al
Rich, what pressure reg are you running ?
Old Sep 8, 2012 | 07:38 PM
ajamesc's Avatar
ajamesc
thanks scott
just type in areoquip on ebay and you will find there shop from there mate and i think in total it was about 200 i think but that dose not inclued having my tank and fuel rail modded nore the cost of my fuel reg
Old Sep 8, 2012 | 07:53 PM
saph_Al's Avatar
saph_Al
James what reg are u runnng an areoquid jobbie ?
Old Sep 8, 2012 | 08:04 PM
ajamesc's Avatar
ajamesc
i have a kinsler reg which is twin return so my rail is modded to center feed and return to reg from iver end
Old Sep 8, 2012 | 08:11 PM
saph_Al's Avatar
saph_Al
So do both your returns T into a single return ?
Old Sep 8, 2012 | 08:14 PM
ajamesc's Avatar
ajamesc
No my reg has 3 ports so iver end of the rail go's to the reg then there is a 3rd port out the bottem that go's back to the tank
Old Sep 8, 2012 | 08:18 PM
saph_Al's Avatar
saph_Al
Yeah that makes sence , Should have thought bout that before i asked
Old Sep 9, 2012 | 12:54 AM
Sonic Boom's Avatar
Sonic Boom
Aeromotive AEI-13109 mate
Rich
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
