K plate 4x4 saph Missfire
I have a customers 4x4 saph in for a missfire, been stood 11 years , has done 27k nouvo red ,
Beautifull car!
No3 cylinder missfire, swapped injectors round, check spark, fit full srnsor kit, check compression, cylinder leak test, check valve lobes and tappet tops for wear , plugs leads etc , everything, boost leak checked perfect!
Still misses on tick over on no3 , plug damp, road test car no missfire only on tick over???
I've now found the fault can anyone guess what it was ?
Beautifull car!
Lol to comments fuel pressure reg diaphragm split leaking high pressure fuel down the vac pipe which connect to inlet right in line with no. 3 cylinder so simple but what a cunt to find!
RB26DETT
Feb 5, 2022 01:54 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
truffleshuffle
Sep 10, 2015 09:35 PM
