Warped Disc ?
Old Sep 3, 2012 | 05:32 PM
Jasoncmor's Avatar
Jasoncmor
Default Warped Disc ?
Hi all.
I had a topic recently about my car pulling to the left.
I now have a bit more insight into my problem.
I raised the drivers side wheel, Span the wheel and there was resistance before coming to a stop.
I turned the engine on and the wheel would turn half way round before stopping on its own, with a little push it would go again, turn half way then stop.
I took the wheel off and pushed the brake disc backwards and it would spin better, So i put on 2 wheel nuts, opposite eachother and if they are tightened roughly the same tightness the same thing happens as when the wheel was on, it would spin a little bit with a bit of resistance, if I loosen one side very slightly, the disc spins effortly and I tried the same with the wheel back on, and the wheel span pretty fast without stopping or resisting. But then If I tighten the nuts the same, there is resistance and the wheel stops again. (remember all this was with the engine running).
I replaced my discs and pads a few months ago, but when troubling shooting the problem, I found that the slide pins on the drivers side were almost seized, so took them apart and put some copper grease on them.
That obviously didnt solve my problem.
The reason I replaced my discs and pads aswell was because one of the pads had cracked very badly and I heard it rubbing.
So is this just a case of a warped disc or is there something more serious going on ?
Cheers, Jason
Old Sep 3, 2012 | 05:35 PM
rsfido_1989's Avatar
rsfido_1989
Did you buy cheap discs?
Old Sep 3, 2012 | 05:37 PM
Jasoncmor's Avatar
Jasoncmor
They are made by pagid, as are the pads, which are supposed to be alright.
Old Sep 3, 2012 | 07:52 PM
rsfido_1989
Swap it with passenger side. See if it does the same thing
Old Sep 4, 2012 | 04:32 PM
martysmartie's Avatar
martysmartie
If the sliders are defiantly free, then you probably have a seized caliper? Remove the caliper and try?
The engine running makes no difference.
Martin
Old Sep 5, 2012 | 09:58 PM
Jasoncmor's Avatar
Jasoncmor
The thing with the engine is when its running and the wheel is off the ground, it will turn slowly by itself.
Old Sep 6, 2012 | 12:02 PM
martysmartie
I presume you have it in gear then?
Martin
Old Sep 6, 2012 | 02:53 PM
Jasoncmor's Avatar
Jasoncmor
No, In gear.
Old Sep 6, 2012 | 02:56 PM
RichieST's Avatar
RichieST
Is the mating face between disc and hub properly clean? When you come to a stop at traffic lights etc do you sit there with your foot on the brake? This is the number 1 cause of warped discs!
Old Sep 6, 2012 | 03:05 PM
Jasoncmor's Avatar
Jasoncmor
I will have a look at the mating face between the disk and hub later.
I will also check to see if the piston is seized.
I don't sit with the brakes on at lights or junctions, no.
I have some spare discs I can try to see if it is the disc.
Thanks
Jason
Old Sep 6, 2012 | 03:07 PM
rog's Avatar
rog
Seized caliper or warped disc, that's the only thing it can be, to me it sounds like the caliper.
Old Sep 6, 2012 | 06:12 PM
Jasoncmor's Avatar
Jasoncmor
If the caliper was seized, would it still work, If only a little bit?
If I brake very hard from say 50-60, it will pull towards the curb, but only If I brake very hard, I did it a few times and then I smelt the brake pads burning.
I will have a closer look.
Old Sep 6, 2012 | 06:33 PM
martysmartie
Originally Posted by Jasoncmor
No, In gear.
That is what I said ^^
I still suspect the caliper, the other thing you can do is measure the "hub run-out"
Martin
Old Sep 6, 2012 | 06:41 PM
Jasoncmor's Avatar
Jasoncmor
Woops, my bad, I mean't not in gear.
What is hub run out and how do you measure it lol.
Old Sep 7, 2012 | 08:41 PM
Jasoncmor's Avatar
Jasoncmor
I checked the caliper, it was completley fine.
The problem was the disc, definately warped, I had a old disc with only a couple hundred miles on that I put on and it worked perfectly.
It still pulls to the side slightly, no where near as much as it did, I assume the brake pulled the tracking out slightly, which ill get sorted when I go to get some new tyres next week.
Cheers for your help.
Old Sep 7, 2012 | 09:29 PM
stevieturbo's Avatar
stevieturbo
C**t
It is impossible for a brake to pull tracking out.
If it pulls to one side when you apply the brakes, one caliper is seized. ( assuming pads/discs are in some sort of usable order and brakes are bled properly )
Old Sep 7, 2012 | 09:34 PM
Jasoncmor's Avatar
Jasoncmor
Calipers definately not seized.
Maybe the garage didnt do it properly, or could be due to the rear sub frame bushes, they are in dire need of replacement which im doing in the next couple of days, I know that can affect it.
If I brake though it doen't pull to the side now like it did, it brakes in a straight line, just veers to the side if Im driving and let go of the wheel.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
SMILER258
Sep 28, 2015 09:04 AM
