focus tdci fan
Old Sep 3, 2012 | 09:59 AM
chris892010's Avatar
chris892010
Default focus tdci fan
Just got a 03 tdci and is the fan is on all the time ahould it be or is there somthing corsing it to be on ??
Old Sep 3, 2012 | 10:18 AM
RichieST's Avatar
RichieST
If the air conditioning is on or the fan control inside the car is set to windscreen (which also turns the AC on automatically) this will make the engine cooling fan run.
Make sure the AC is off and the fan control is set to face or something and see if it goes off.
Old Sep 3, 2012 | 12:52 PM
martysmartie's Avatar
martysmartie
Exactly what he ^^ said.
Martin
Old Sep 3, 2012 | 06:03 PM
The wifes 1.6 16v 53 reg focus does it all the time the air con can be switched off and when you start the car the rad fan comes straight on.
My friend over the road,his focus did the same.
Old Sep 4, 2012 | 06:28 AM
zippyobrien's Avatar
zippyobrien
On the petrels it means the cylinder head temp switch has failed.
Old Sep 4, 2012 | 04:27 PM
martysmartie
It's irrespective of the A/C, as said above, if the direction is set to windscreen the A/C is on!
Martin
Old Sep 4, 2012 | 04:50 PM
focus 4x4's Avatar
focus 4x4
The fan relays are known to play up , fords change lots of these . They wife's fiesta mk7/8 Zetec s fan relay recently packed up and ran the fan constantly till the battery was dead ! Changed the £23 relay , problem sorted.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
simonmcf
Sep 22, 2015 08:40 AM
talon1
Sep 15, 2015 10:27 AM
marky_g
Sep 12, 2015 04:26 PM
