mk2 mondeo st engine in to a mk2 Granada
Just wondering whats involved in doing it. Would I need custom mounts and what box to use as I want a manual and mines is a auto.
think the bell housing bolt pattern is different.
A great engine though and with it being light in comparison to the all iron V6 you should benefit all round. I have always thought about one in a Sierra...
In fairness thinking about it it may be possible to spin the inlets round. It would require some thinking about but "may" be possible and need some one off bits. I suppose you'd need to measure up and see how it can fit you might have enough room to keep it as is and re route a longer intake pipe to the tb.
As I said you could do with an engine hung in place on a crane or the like to see where the mounts will go and see how close the tb is to the bulk head.
If you do it go for a 200 engine as those of us with 24s spend our time bolting 200 bits on and chasing 200 power anyway hth
just get the s-type jag 3.0 with manual box, its basicly an st220 engine already spun 90*, and its just a 3.0 version of the st24/st200 2.5 engine, and is factory 240hp
never thought of that then a gain id be as well doing a granny v6 cossie. fancy something a bit different got a few other ideas
if u want different, use the jag s-type v6 box and stick it behind the volvo xc90 v8, same engine as mondeo st's but with 2 extra cylinders, now thats different, don't know if the box would take the v8 power, or find a 3.5 eco boost v6 from america, same engine but twin turbo
JoeyBoyden
Jan 4, 2024 02:36 PM
