smell of fuel in oil and smoke when let off the throttle
Old Aug 31, 2012 | 07:04 AM
RS BINE's Avatar
RS BINE
Default smell of fuel in oil and smoke when let off the throttle
Morning people. first off noticed a smell of fuel in my oil when checking it and also car smokes a bit when i let off the throttle. just had my tappets and stem seals done a few weeks ago and car was also set up about a month ago. Planning a compression test when i get home. any other help or thots wud be appreciated.
Old Aug 31, 2012 | 12:03 PM
RS BINE's Avatar
RS BINE
bump...
Old Sep 3, 2012 | 11:15 AM
RS BINE's Avatar
RS BINE
anybody????
Old Sep 3, 2012 | 03:36 PM
Farmer Giles's Avatar
Farmer Giles
have you changed the oil since it was set up again ?
if it's been badly overfuelling for a while that could account for the fuel in the oil and could also cause premature wear in the bores due to bore wash.. basically the excess fuel removes the oil film from the bores and the rings wear faster.
if the oil is thinned out by the fuel it could be passing the rings easier..
Get a comp test done and change the oil and see what you're left with if the comp test is 'normal'..
hth
Old Sep 4, 2012 | 05:18 AM
RS BINE's Avatar
RS BINE
cheers for the reply.no havnt changed the oil since it was set up. was runnin fuchs pro race 5/30 but goin to change to millers cfs 10/40. will get compression test done as soon as i get back from offshore and change the oil. but starting to think they mite b gone with getting smoke on lift off also.
Old Sep 4, 2012 | 11:26 AM
saph_Al's Avatar
saph_Al
Is it possible one of the stem seals wasn't seated quite all the way and it's popped off or did you use the Top hat style ones ?.I only ask because i made the same mistake myself. Oh and i assume were talking about the S2 in your Profile pic ? .
Old Sep 4, 2012 | 12:32 PM
RS BINE's Avatar
RS BINE
hi Al, aye its the s2 in the pic and used the top hat ones.
muffster
13
Sep 3, 2015 09:40 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
