ST170 thermostat housing
Aug 30, 2012 | 12:29 PM
Can you still get the housings from ford.My mates from work is leaking from around the housing.I coulld be the gasket.
Aug 30, 2012 | 03:14 PM
Most likely a cracked housing mate,
These crack quite regular
Aug 30, 2012 | 04:47 PM
I have one Genn. Off the engine in my mk2 escort
Aug 30, 2012 | 08:13 PM
Quote:
Originally Posted by
Mark_
I heard it was a common thing.Im sure i heard that ford no longer sell them.
Aug 30, 2012 | 08:14 PM
robrs2
It my mate needs one i might get it off you for him.
Aug 30, 2012 | 08:24 PM
It will be the rubber seal on the bung that fits into the bottom of the housing! You can get a new bung and seal from Ford. Very common on the st170.
Aug 31, 2012 | 04:40 PM
When your under the car it looks like the coolent is coming from inbetween the head and the thermo housing.
Sep 1, 2012 | 08:37 PM
Well it is very very very common for the plug seals to fail on the st170 so I'd deffo be looking at that first. You can't see it easily as it is underneath the thermostat housing.
Sep 24, 2012 | 09:08 PM
If the stat housing does turn out to be cracked, don't bother buying a second hand one. The three torx screws that hold the stat cover on normally rot into place and snap when you go to undo...
Learnt from experience lol...
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
fordrallycar
Sep 30, 2015 07:57 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
2000 ,
dummy ,
focus ,
ford ,
housing ,
plug ,
screws ,
st170 ,
thermastat ,
thermostat ,
torx
