300mm brakes on frst (st170 or mondeo)
Old Aug 29, 2012 | 07:10 PM
chrisxr2it3's Avatar
chrisxr2it3
Default 300mm brakes on frst (st170 or mondeo)
I'm thinking of putting bigger brakes on the front of my frst iv currently got st150's on their but iv got rid of the rear drums in favour of st170 rear hub setup an iv been told that having near enough the same size discs on the back isn't a good thing? Iv also been told that I can use mk3 mondeo front calipers with st170 discs or calipers an discs from the st170. I no with both I have to drill the hubs from 10 to 12mm but I don't no if I have to add washers or spacers to make them fit correctly? I would prefer to have them fitted without washers ect any help or advise on this
Thanks in advance
Chris
Old Aug 29, 2012 | 07:17 PM
Steve Escos's Avatar
Steve Escos
Yep you can use mondeo calipers or st170 calipers. You may have to use spacers dependant on the hub. I have done the conversion on my escort. If I remember correctly you need to fettle the calipers to get them under zetec s alloys or will need to run 16's See my post in RS turbo parts for all the parts you need.
Old Aug 29, 2012 | 08:16 PM
zippyobrien's Avatar
zippyobrien
Mondeo calipers. St170 discs. No spacers.
Awsome set up !!! But do t go eBay discs. Either get gen ford std discs. Or proper ebc or tarox ect.
Old Aug 29, 2012 | 08:47 PM
chrisxr2it3
Steve escos
Cheers mate il have a look,il be running 16" comps so should clear them no bother
Zippyobrien
Cheers mate,I work for a motor factors to can get ebc tar-ox for reasonable money so that's what il go for
Old Aug 29, 2012 | 08:49 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
why stop at 300mm discs, i have rota competition wheels and with a home made spacer and time machining callipers you can get FRS mk1 discs and callipers on, four pot brembo's with 324mm discs.
just food for thought, not sure how comps would fare though.
Old Aug 29, 2012 | 08:56 PM
zippyobrien
As above.
I've got evo8 calipers and 324 mm discs under 16"comps.
But for road the 300mm is great mate.
Consider ungrading to a mk5 rs2000 master cylinder or Mondeo mk3 one.
You gunna be pushing ALOT more fluid around now.
Old Aug 29, 2012 | 09:00 PM
luke19790_3's Avatar
luke19790_3
i've got this setup for sale
Old Aug 29, 2012 | 09:53 PM
chrisxr2it3
Is their a lot of work involved in changing to the mk3 servo
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 20, 2015 11:47 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
focus2351
Sep 9, 2015 09:33 PM
