General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
not sure what engine i have? iv been told its an escort ( engine is not in yet) its got an escort inlet manifold. im hoping its the fiesta so i can run efi, where is the hole for the crank sensor is it next to the crank pulley? with an allen key bolt? if someone could help me would be really appericated cheers
Picture would help or you can check by looking for the hole in the block. It's on the flywheel side, down by where the starter motor would be (if yours is front mounted).
Just get hold of an EFI block to take a template of where the sensor should be and then drill away! It takes a while though but I've known someone who's done it.
