msd anti lag and launch controll
Old Aug 28, 2012 | 06:43 PM
B13 JUS's Avatar
B13 JUS
Default msd anti lag and launch controll
does anyone know what pins you earth on a l8 ecu for msd al and lc?
Old Aug 28, 2012 | 06:49 PM
James @ M Developments.'s Avatar
13 and 14
Old Aug 28, 2012 | 07:00 PM
andy escos's Avatar
andy escos
Originally Posted by James @ M Developments.
13 and 14
come on James which is which
Old Aug 28, 2012 | 07:06 PM
B13 JUS's Avatar
B13 JUS
Is it a case of running a wire to each pin and earthing it out?
Old Aug 28, 2012 | 07:10 PM
He didn't ask that
Old Aug 28, 2012 | 07:13 PM
andy escos's Avatar
andy escos
He didn't ask that
lol your mean
Old Aug 28, 2012 | 07:14 PM
Yeah just run a wire from 13 and 14 and put it to ground via a switch.
The plug that 13 and 14 are on also has a 3rd pin which is ground, I use that for the ALS ground, and use the handbrake switch to ground the LC so it only works with the handbrake up
Old Aug 28, 2012 | 07:16 PM
Miller 3's Avatar
Miller 3
ALS is pin 13
Launch control is pin 14
You just earth that wire and that feature is enabled.
Originally Posted by Miller 3
ALS is pin 13
Shhhhhh lol
Old Aug 28, 2012 | 07:17 PM
andy escos's Avatar
andy escos
I knew you knew always been good with the technical stuff
Old Aug 28, 2012 | 07:23 PM
B13 JUS's Avatar
B13 JUS
If the chip didn't have al&lc would it damaged the ecu?
Old Aug 28, 2012 | 07:33 PM
Miller 3's Avatar
Miller 3
I think it opens a parallel universe mate if not active lol
Old Aug 28, 2012 | 08:58 PM
KSA-Cossie's Avatar
KSA-Cossie
That's how I did mine.
Doug..............................................
Old Aug 28, 2012 | 09:21 PM
Rsmat's Avatar
Rsmat
Mine works even tho only used it 3 times ... Not used the LC yet tho.
Old Aug 28, 2012 | 09:26 PM
Miller 3's Avatar
Miller 3
The als is brill with the lc at the same time... try it matt
Old Aug 28, 2012 | 09:51 PM
Rsmat's Avatar
Rsmat
Will do mate
Old Aug 29, 2012 | 08:50 PM
jamie's's Avatar
jamie's
any info or pics of how to mod the throttle body/idle valve?
as i'm gonna finaly fit mine this weekend and have long since lost the instructions i got with it, msd stuff btw
Old Aug 29, 2012 | 08:52 PM
mechanic28's Avatar
mechanic28
while using the launch control or anti lag?
Old Aug 29, 2012 | 09:06 PM
jay's Avatar
jay
What do I need for anti lag??
Old Aug 29, 2012 | 09:11 PM
Rsmat's Avatar
Rsmat
He means use them both together at the same time.
Old Aug 29, 2012 | 10:36 PM
mechanic28's Avatar
mechanic28
i just wondered if you can use both together when you want to launch control it or if you just using the anti lag
Old Aug 30, 2012 | 05:38 AM
Miller 3's Avatar
Miller 3
Doug bring the car round il show you how to use it properly mate lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Fezman1
Oct 2, 2015 01:22 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
