Clio cosworth 4x4
Hi all ive come a Clio Cosworth 4x4 Dimma absolutely mint conversion (not cozi floor pan) this is proper weapon, im wondering how to register the vehicles change of wheel plan and or model type as well as engine size. thanks, anyone interested i will post some pics and the spec thanks
I believe if you tell them now about the engine and conversion to 4x4 etc they are most likely to put it on a Q reg I'm afraid
I have the same issue with my 4x4 fiesta cosworth so will have to cross this bridge soon
I wouldnt bother mate, m,ore hasle than its worth, i would check along the lines of vosa / vic check ? I think if the check it and they are happy with it you might not need to register it on a q plate but dont hold me to that!
Pics coming up soon, having a big spec engine build at the moment, car was built by DJ motorsport over 20k spent on it, but not by me, i got it cheap as the chap ran out of patients and money i suppose, believe me what a car fantastic fabrication, bill for Ł6500 for conversion alone, running full 4x4 gear, 200 block, h-beam rods, wisecos, 91mm, ACL, greys , stage 4 l8 ecu ect ect.
As the project goes on i will post more if your all interested. just waiting for engine to be finished then thats about it, 8 years of hard graft by previous owner and i get to complete it, cant wait engine will be complete and in by the end of September, hopefully running over 400bhp.
Nice, ive got everything now just waiting for 200 block to come back from engineers bored to 91mm to accommodate the pistons, head been fully ported double valve springs, T60 - 1 stage 3 turbo bla, bla, bla, you get the picture, who built yours mate, have you got all the digital gauges, this was fitted with em, just cant believe how cheap i got it, i purchased it blind off ebay, no pics, when it was delivered i was gob smacked expecting a bag of shite, i was wrong.
yes was paint about 6 years ago bare metal paint job, costing 5k but dont know the paint code to get the bumper done, called the chap who painted it but he cant remember the paint code, and its not on the receipt, shame, i think its a ford colour though
Engine build so far
reworked 200 ds motorsport block decked
ds motorsport h beam rods arp bolts
wiseco 91.5 mm pistons
polisheshed crank
acl big ends
acl mains
acl shims
arp stud and nut kit
high pressure 4x4 oil pump
bottom end cometic gaskets
new seals
4 paddle clutch kit
new release bearing
pressure plate
4x4 fly wheel
new spigot bearing
front mount intercooler
pro alloy radiator
oil cooler kit
4x4 samco coolant hoses
head full refurbished
skimmed
3angled valve seats
rs500 t4 turbo
greys
15mm plenum spacer
l6 stage 4 ecu
4x4 cosworth brakes all round
green stuff pads
braided brake hoses
coilovers
abs / pas
4 wheel drive
polisheshed crank
acl big ends
acl mains
acl shims
new seals
4 paddle clutch kit
new release bearing
pressure plate
4x4 fly wheel
new spigot bearing
pro alloy radiator
oil cooler kit
skimmed
3angled valve seats
rs500 t4 turbo
greys
15mm plenum spacer
l6 stage 4 ecu
green stuff pads
braided brake hoses
coilovers
abs / pas
4 wheel drive
New pictures added, nearly time to start her up, this weekend when new water pump arrives, spent more than i planned to, gone to town on this build, NEW REWORKED 200 DS MOTORSPORT BLOCK DECKED
DS MOTORSPORT H BEAM RODS ARP BOLTS
WISECO 91.5 MM PISTONS
COMETIC MULTILAYER HEAD GASKET 5 LAYER SPECIAL
COMETIC TOP END GASKET SET
4X4 TURBO FEED HOSE
COMETIC ROCKER GASKET
ONE OFF 4X4 WASTEGATED CAST MANIFOLD
EXTERNAL WASTEGATE
POLISHESHED CRANK
NEWMAN CAMSHAFTS BD10 EXHAUST / BD14 INLET
NEW CAM FOLLOWERS
VERNIER PULLEYS
ACL BIG ENDS
ACL MAINS
ACL SHIMS
ARP STUD AND NUT KIT
HIGH PRESSURE 4X4 OIL PUMP
BOTTOM END COMETIC GASKETS
NEW SEALS
4 PADDLE CLUTCH KIT
NEW RELEASE BEARING
PRESSURE PLATE
4X4 FLY WHEEL
NEW SPIGOT BEARING
FRONT MOUNT INTERCOOLER
PRO ALLOY RADIATOR
3 PORT BREATHER WITH MIRROR IMAGE TANK
POLISHED COOLANT TANK
OIL COOLER KIT
4X4 SAMCO COOLANT HOSES
044 FUEL PUMP
3 BAR MAP SENSOR
FUEL PRESSURE REGULATOR
HEAD FULL REFURBISHED
SKIMMED
3ANGLED VALVE SEATS
RS500 T4 TURBO
GREYS
15MM PLENUM SPACER
L6 STAGE 4 ECU
4X4 COSWORTH BRAKES ALL ROUND
GREEN STUFF PADS
BRAIDED BRAKE HOSES
COILOVERS
Plus much more, what do you think?
4X4 TURBO FEED HOSE
EXTERNAL WASTEGATE
POLISHESHED CRANK
NEW CAM FOLLOWERS
VERNIER PULLEYS
ACL BIG ENDS
ACL MAINS
ACL SHIMS
NEW SEALS
4 PADDLE CLUTCH KIT
NEW RELEASE BEARING
PRESSURE PLATE
4X4 FLY WHEEL
NEW SPIGOT BEARING
PRO ALLOY RADIATOR
OIL COOLER KIT
044 FUEL PUMP
3 BAR MAP SENSOR
SKIMMED
3ANGLED VALVE SEATS
RS500 T4 TURBO
GREYS
15MM PLENUM SPACER
L6 STAGE 4 ECU
GREEN STUFF PADS
BRAIDED BRAKE HOSES
COILOVERS
I usually hate body kits but there's something about the Dimma kits I like. Back in the day There was a girl near me who had a dimma clio with mi16 on carbs, looked superb. Then she had a pearl white Dimma Clio, also looked amazing.
Lot of work gone into yours. The silver mesh lets it down big time though! Halfords sell the same thing in b,ack, looks a lot better.
Thanks for all your comments rest of parts came today, firing her up sat will video it for all to see, hopefully no more snags, fitted new water pump and that has cured that problem, no more leaks. fingers crossed for the weekend.
Think that colour maybe dark aubergine?
Lovely conversion,there was a dimma Clio on retro rides recently for cheap money,crying out for a nice Volvo esque t5 type rwd conversion!!!
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
