Mk4 S2 RST parts garage clear out job lot
As per title I have the following stuff to get rid of out of my garage it's stuff I have collected over the years here goes
S2 rst gearbox
Escort gti gearbox
S2 rst rear bumper (white)
Mk4 xr3i exhaust system (near new)
1 full box of looks bits door, tailgate looms etc...
1 box of central locking motors (approx 20)
1 s2 rst gearbox
3x s2 rst gearbox cradles
2 sets of non abs rst drive shafts
1 pair of s2 rst abs driveshafts
3x pairs of rst front hubs
5x rear brake drums
3x rst master cylinders
3x rst rear hubs
1 pair of rear shoes (used)
1 brake fluid res
1 rear brake load comp valve
1 rear arch repair Pannel (new)
1 near new 5 speed gear selector
1 pair of front inner arch liners
1 pair of mk4 cab rear lights
2x driver side can rear lights
1 pass side headlight
1 pass side amber front indicator
2x sets amber side repeaters
1 cab roof tension wire
1 pair of clear front indicators
1 mk4 front driver side clear indicator
1 escort gti rear boot carpet
3x sets of white rst wing mirrors
1x set of red wing mirrors
1 set of green wing mirrors
2 set of black wing mirrors
1 set of black manual mirrors
4 xr3i radiators
1 box of mk4 seat belts
3x pairs of 90 spec sun visits (beige)
9x windscreen wiper stalks
3x indicator stalks
4x centre stereo units
1x pioneer head unit
2x sets of interor door handles
1 mk4 ignition barrel housing
4x gear stick surrounds
3xre heater consoles
2x speedo surrounds
3x fuse box covers
2x glove box doors
1x can electric roof centre console
1 set of side skirt hangers
3x sets of inner sill trim
1 RS steering wheel
1 set of mk4 cab speaker covers with pioneer speakers fitted
1 set of mk4 can boot trim
2 sets of mk4 cab rear door cards
1 set of mk4 can rear speaker pods
1x mk4 rst pass side skirt
Both sides rear arch kit
3x mk4 cambelt covers
3x rst starter motors
6x ignition coils
2x rst fuel pumps
1 xr3i distributor
3x rst engine mounts
4x rst gearbox mounts
2x sets of mk4 boot hinges
1x 90 spec washer bottle
1x 88 spec washer bottle
4x sets of mk4 bonnet hinges
1x mk4 bonnet catch
3x rst accelerator pedals
1x rst pedal box
1x rst intercooler
6x heater blower motors
1x rst fuel ECU
1x p100 Td header tank
1x rst rear anti roll bar
4x rst steering racks
2x mk4 steering columns
1x mk3 steering column with barrell and key
5x speedo cables
5x clutch cables
1x rst arb mounting plate with towing eye
1 rst pass side bonnet vent
1x Sierra cosworth center console
5 pairs of mk4 window motors
5x wiper arms with blades
1x Zetec rocker cover
1x tail pipe trim
1 pair of rs2000 window motors
1x rs2000 electric lock
1x escort gti down pipe with cat
1x set of rs2000 red bump strips
1x escort gti air mass meter
1x escort gti engine mount
1x rst g max Front shock
1x rst g max rear shock
1x pair of new rst rear coil springs
Various mk4 window glass
1 brand new rubber Cvh rocker cover gasket
1x rst inlet manifold
1x xr3i inlet manifold
Various rst gaskets
2x rst fuel rails with sensors
1 brand new rat cambelt
2x rst fuel accumulators with brackets
1 rst fuel pump cradle
Various fuel lines with injectors
1 x brand new mk3 escort inner sill
2x cab tannau covers
Various water hoses
And loads of little bits and pieces I couldn't be bothered to write down!
I want £350 for the lot collect ASAP
S2 rst gearbox
Escort gti gearbox
1 s2 rst gearbox
5x rear brake drums
3x rst rear hubs
1 brake fluid res
4 xr3i radiators
3x indicator stalks
2x speedo surrounds
3x fuse box covers
2x glove box doors
1 RS steering wheel
6x ignition coils
2x rst fuel pumps
1 xr3i distributor
1x mk4 bonnet catch
1x rst pedal box
1x rst intercooler
1x rst fuel ECU
5x speedo cables
5x clutch cables
1x tail pipe trim
Various rst gaskets
Various water hoses
I literally need just the interior door handles as mine were painted black at some point.
As long as they have window switch holes I'd like them please if you can do that?
That's a shame, if you decide to let me have a pair of door handles let me know, everyone throws em away thinking there's hundred lying around.
Fair old amount of decent stuff there too!
Billy_RS
16
Oct 11, 2025 09:41 PM
