Hydraulic clutchs
Aug 20, 2012 | 06:38 AM
Hydraulic clutchs
Any one had any problems with there's mine the biteing point seem to move up as the more i i use ie in trafic
Any thoughts
Aug 20, 2012 | 06:53 AM
fluid must be getting hot is the only thing i can think of wot car is it mite help
Aug 20, 2012 | 08:02 AM
Aug 20, 2012 | 08:09 AM
Quote:
Originally Posted by
fordrallycar
Escort Cosworth Fella
If it's one of my kits give me a call.
Aug 20, 2012 | 09:02 AM
I'm suffering this as well?
Aug 20, 2012 | 09:18 AM
Martin-Hadland
I believe it is martin it came off Warren Kellys Cosworth
Aug 20, 2012 | 11:53 AM
has it been bled properly?
Aug 20, 2012 | 12:47 PM
Fluid possibly boiling.
Change the flexi for a braided line and get some fresh fluid in there
Aug 21, 2012 | 06:01 AM
Cheers guys i will try what you all have suggested
Aug 21, 2012 | 08:43 AM
remember to use only dot4, not dot5 or you will ruin your seals.
Aug 21, 2012 | 04:24 PM
Dot5 ruins the seals on what, the master and slave cylinders? I've not heard of that. Any more info?
Aug 21, 2012 | 06:00 PM
AP racing told me not to use dot5 on my ap setup (mc and slave) as it will wear out the seals.
Aug 21, 2012 | 06:39 PM
Dot 5.1 should be ok though if it's the silicon fluid you need to avoid as 5.1 is glycol based same as dot 4
Aug 21, 2012 | 09:50 PM
It said in the instructions specifically not to use dot5.1 (i meant dot5.1 when writing dot5), this is for AP Racing slave cylinders - but I contacted them regarding this and they said it would damage the seals so I just agreed.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
