m.o.t rules for half stripped out race/ road cars
Old Aug 17, 2012 | 08:51 PM
lukeytheduke's Avatar
lukeytheduke
Default m.o.t rules for half stripped out race/ road cars
my saph is on for an mot this week but has no back seats, seatbelts are still there no door cards but u can still open and close doors via the handle to open it and u can grab a whole in the metal to close it again.
Also the lower dash is out exposing some bare wire. Its got a cage in to.
Will i get any trouble at all? Cheers for your help. Luke
Old Aug 17, 2012 | 08:53 PM
carfixz's Avatar
carfixz
if the seats are missing then the belts dont get tested, no door cards, no problem, hanging wires no problem
Old Aug 17, 2012 | 08:59 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
why the seat belts if theres no seats? it used to be if it wasnt there it wasnt tested with many things like rear seats, belts, spare wheel etc. i dont know if thats still the case.
Old Aug 17, 2012 | 09:22 PM
lukeytheduke
cheers lads. Its an ongoing project so only stripped the basics out. I know u have to be able to open and close the door. U can open it fine but not sure if they class using the wholes in the metal as acceptable way of closing the door?
Old Aug 17, 2012 | 09:33 PM
bigluke200's Avatar
bigluke200
As above, no probs at all!
Old Aug 17, 2012 | 09:35 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
if you dont use them any more (no rear seats) it basically turns into a van and therefore nowt really matters in the back
if you take the belts out remember the holes are straight out the floor and need bunging
Old Aug 17, 2012 | 10:11 PM
lukeytheduke
what about the front door card situation. Can anyone clarify that please?
Old Aug 17, 2012 | 10:15 PM
bigluke200's Avatar
bigluke200
No door cards in my 3dr.. Passed no probs
Old Aug 17, 2012 | 11:31 PM
skippy,rst's Avatar
skippy,rst
deffo dont need door cards mate...
Old Aug 18, 2012 | 12:19 AM
RS2000CUSTOM's Avatar
RS2000CUSTOM
If the MOT is carried out correctly and passes then simply expect loads of Advisories as any decent tester will list things that would normally have been tested which have subsequently been removed.
BUT be aware of 'Must Have" items as if they inoperative or missing it will still fail anyway
Old Aug 18, 2012 | 05:04 AM
lukeytheduke
What have v got to close the front door with??
Old Aug 18, 2012 | 05:46 AM
Rsmat's Avatar
Rsmat
I bet he closes it with his hand mate.....
If in doubt Luke make a string handle.
Old Aug 18, 2012 | 05:54 AM
bigluke200's Avatar
bigluke200
Lol, yep just my hand You don't really need anything mate.
Old Aug 18, 2012 | 06:13 AM
Rsmat's Avatar
Rsmat
Quality lol....
Old Aug 18, 2012 | 07:19 AM
lukeytheduke
hahaha. fuck it string handle it is then lol!
What about the interior mirror that hangs from top of windscreen? I got those bollox sticky pads from halfrauds and they last a week. Do i have to have this mirror to pass an mot?i think i read somewhere u do need it?
Old Aug 18, 2012 | 07:31 AM
Rsmat's Avatar
Rsmat
Yea mirror you need mate
Old Aug 18, 2012 | 09:03 AM
lukeytheduke
cheers lovers!x
Old Aug 18, 2012 | 09:19 AM
DAN-Saff's Avatar
DAN-Saff
Iirc you only need 2 mirrors on the car - like a van with metal rear doors
Old Aug 18, 2012 | 10:25 AM
jamie's's Avatar
jamie's
you need the the drivers side wing mirror and 1 other,
the other could be either passenger mirror OR interior mirror
so if you got a passenger wing mirror then the interior mirror is NOT required
Old Aug 18, 2012 | 10:41 AM
c612_woody's Avatar
c612_woody
if it aint there it cant be tested
Old Aug 18, 2012 | 11:43 AM
mechanic28's Avatar
mechanic28
the back doors you dont need to be able to open or close them u just need to check they are securely shut
Old Aug 18, 2012 | 01:31 PM
lukeytheduke
haha that is quality. So i have drivers side and passanger side wing mirrors so i defo dont need the one on the windscreen? So i presume the police if they kick of about it cant do anything either?! Cheers. Luke
Old Aug 18, 2012 | 03:56 PM
stevieturbo's Avatar
stevieturbo
C**t
A car is not a van
From around 1986, a car must have the full compliment. 2 exterior and 1 interior.
As for seat belts....pretty sure the car would fail here if it had belts and no seats. Your MOT may be more flexible in that respect.
As for door cards. As long as there is a means of opening and closing the doors, and there is nothing of any danger to the occupants then it shouldnt matter.
Old Aug 18, 2012 | 05:51 PM
lukeytheduke
any mot testers help me out on the seat belt question?
Old Aug 18, 2012 | 05:58 PM
mechanic28's Avatar
mechanic28
ahhh be careful there mot and law are two different things lol but no u wont get done by the police for not having a interior mirror and ref seatbelts,if there is a seat there it has to have a working belt if there is no seat then there needs to be no belt although u should get a advise for it
Old Aug 18, 2012 | 06:23 PM
stevieturbo
C**t
Just checked the manual here. I stand corrected.
If a belt is fitted, but there is
no corresponding seat it is not considered to be a seat belt, for the purpose of
this inspection.
If it's ok here, good chance you're ok over there.
Mirrors...weird this must have changed. Or differs from the legal Construction and Use stuff. Definitely 1986 on C&U states it must have all 3, as Ive queried this with the police before.
Taken from our MOT manual
Obligatory mirrors are:
a. An exterior mirror fitted to the offside side(right-hand side when seated in the driver’s
seat, or
b. An exterior mirror fitted to the nearside (left-hand side when seated in the driver’s
seat, or
c. An interior mirror.
Note:
A motor vehicle (not being a goods vehicle or a bus) first used before 1 June 1978
must have any one of the above options.
A motor vehicle (not being a goods vehicle or a bus) first used on or after 1 June
1978 but before 26 January 2010, must have two mirrors, one of which must be option ‘a’.
All goods vehicles first used before 26 January 2010 must have two mirrors, one of
Old Aug 18, 2012 | 07:34 PM
jamie's's Avatar
jamie's
irish must be differant rules regarding mirrors as over here you defo only need the offside plus 1 other, dont know why so many rule changes between the 2 countries
Old Aug 18, 2012 | 07:38 PM
fuzzy's Avatar
fuzzy
why does it have "or" after the mirror quotes? if you have 1 of those 3 is it ok?
Old Aug 18, 2012 | 07:53 PM
stevieturbo
C**t
the link above confirms that Northern Ireland MOT does actually only require 2.
I'm pretty sure Construction and Use states differently though ! Just cant find anything
Old Aug 18, 2012 | 08:04 PM
jamie's's Avatar
jamie's
yeah i just re-read that
my bad
Old Aug 18, 2012 | 08:06 PM
cossirob's Avatar
cossirob
nope they must be able to open and close from the outside
Old Aug 18, 2012 | 08:11 PM
mechanic28's Avatar
mechanic28
no rear doors have to be securely shut front door you have to be able to open from inside and out side
Old Aug 18, 2012 | 08:12 PM
mechanic28's Avatar
mechanic28
2 out of the 3 but one of those two must either be off side or interior mirror
Old Aug 18, 2012 | 08:16 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
You have to be careful as a lot of things on construction and use dont come under MoT. People need to remember that MoT is only the minimum basic assessment of key "roadworthyness" factors.
People building trackday cars etc are best to read up on IVA testing criteria as it is based on much of the construction and use regulations but limited for none mass produced cars, kit cars and rebuild/radically altered cars.
Most moderately modified cars would in a legal sense these days probably be classed as a Radically Altered Vehicle in VOSA's eyes and thus should be IVA'd.
Its something that WILL come back to bite the modified scene in the next few years. It is illogical to make it so you have to IVA a kit car but not a road car rebuilt with mostly modified parts.
Weve just been able to get away with it for as long as we have by luck really and people not being too stupid. However as per usual in this country, the mongs have ruined it for the rest of us and the idiot chav racers and VW "scene" faggots with bodged and dangerous mods have drawn unwanted attention to our scene and its only a matter of time before the pressure to enforce the current legislation becomes strong enough.
yes thats right for those who arent already aware, many highly modified cars are illegally on the road and under current legislation should have been IVA'd already. The legislation is already in place (and has been since SVA was introduced) its just that only a few VOSA officials and cops have the knowledge and motivation to enforce it. They have already proposed many changes to MoT to combat it and we are lucky that only a few have got through due to problems with implemention and practicality of enforcing it on a large scale.
Although i suspect when it does come it will be quite simple to refuse an MoT until a IVA test pass has been issued. Probably using the same means they use to catch out kit cars still running on the donor ID.
To be fair i see forced IVA on modified cars as a good thing. based on a type approved road car, almost all the standard bits and areas will already meet the standards anyway so its just the modifications and much of the common mods wont be a problem anyway. It also removes the grey areas often encountered with modified cars. prime example is exhaust noise which is open to interpretation. Under IVA the noise limit is absolute, plain and clear and its easy for us to comply and then no copper can challenge it either (well he can but wont win).
Old Aug 18, 2012 | 08:30 PM
stevieturbo
C**t
Isnt there the issue that a lot of classic cars simply would not pass an IVA regardless ? Certainly when the talk came in about all this nonsense, that was what the magazines and bodies acting on the classics behalf were saying.
IVA is based on modern rules, many of which an old car would never be able to pass as IVA didnt take into account vehicle age.
Noise is an odd one though. Ive a friend with a Victory Hammer 1800cc V-Twin with open pipes that was IVA'd or whatever the bike equivalent is. Loud is an understatement !
Old Aug 18, 2012 | 08:42 PM
nicksaph's Avatar
nicksaph
rear doors need to open from inside and outside now as of 1st jan this year.
there's lots of new fail items that started coming in from 1st jan this year they are bringing them in perioddicly during the year
the mirror that must be fitted is the off side mirror.
if it hasn't got that one it will fail even is the nearside and interior ones are fitted
Old Aug 18, 2012 | 08:48 PM
mechanic28's Avatar
mechanic28
correct on the rear doors but it only have to opened from the outside i never knew that,good job i have always checked they opened anyway even tho i thought it was not part of the test anymore,i have learned something new lol
Old Aug 18, 2012 | 08:54 PM
Psycho Warren
Carbon Crazy
I doubt most highly modified classics that come under IVA would really struggle. Normal classics where originality is key are not affected.
Have a read of the regs and to be fair there arent many things that are impossible to solve.
replicas of 1930s cars with suicide doors and sharp as fuck cycle wings get through and loose none of the original character so im sure it wouldnt be a big deal.
Sure you might have on some really old cars, the additional fitment of side repeaters, rear fog and reverse lights and a few things like blunted edges and improved brakes, but is that a bad thing??? and again its only going to affect modified cars which by definition arent really that bothered by originality.
emissions is no problem as its engine age based.
noise like emissions is based on age of the test. eg IVA noise rules are tighter than SVA. However nothing as yet is retrospective. Also noise is done at a certain RPM based on peak power and also a set position of the noise meter. certain engines will due to power band get away with it easier than others.
have a read through the IVA manual or one of the kit car magazine summaries as its really not that bad.
Old Aug 18, 2012 | 08:59 PM
cossirob's Avatar
cossirob
Sorry but rear doors only need to be able to open from the outside, doors must be easy to open and close for hinges, catches and pillars to be inspected.
Also like nick said the offside mirror is obigatory but you do need one of the other two
Old Aug 18, 2012 | 09:16 PM
Psycho Warren
Carbon Crazy
ive got a good one for you.....
a lot of MoT places seem to be more rigidly enforcing rules onprescribed areas of visibility to the extent of failing cars for having a magic tree hanging off the rearview mirror.
now obviously the rearview mirror is excluded as a failure point for obscuring visibility.
So what would happen if you removed the mirror on say a semi track car with carbon rear window and in its place put a go pro camera or similar??
Logic would dictate that visbility is no worse impaired so it is no more unsafe than if a rear view mirror was in the same place.
However, would the fact it is a camera, NOT a mirror mean it has no exception to the visibility rule and thus be a point of failure???
a practical example. I have a camera in front of my mirror for trackday use and insurance purposes. it is deliberately located to not obscure driver visibility of the road and is entirely behind the mirror when sat looking from the drivers seat. Perfectly legal under current MoT rules. If i fitted carbon rear windows to save weight (i cant see much out back due to spoiler anyway so no visibility loss in practical sense) and removed the redundant mirror, would the camera now be a fail point??
