Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Temp going into red when on motorway/higerh speeds
Old Aug 15, 2012 | 05:54 PM
Tailor1's Avatar
Tailor1
Default Temp going into red when on motorway/higerh speeds
Hi Just joined, I have a 2001 reg ford focus, the temperature gauge keeps going into the red when driving on the motorway. I've had the thermostat changed which worked ok for a while but the problem has returned .
driving at normal speeds no problems. had the water pump changed a couple of years ago, flushed the radiator the other day, got a new sensor
not over heating at all, not losing water just puzzled to what the hell going on , tried a new expansion cap which made no difference ,
Any one else had this happen and how did you fix it
Thanks
Old Aug 15, 2012 | 06:03 PM
JamesH's Avatar
JamesH
The only thing you've not done that springs to mind, is the head gasket
Old Aug 15, 2012 | 06:09 PM
Tailor1's Avatar
Tailor1
I'm not losing no water & the diagnostics said it was all working fine just a fault with the cyclinder head sensor which I replaced still same probs
Thanks mate for replying I'm a real forum virgin as never been on one in my life - my mechanic is puzzled , he thinks its dashboard - do you think it worth change that
Old Aug 15, 2012 | 06:11 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Maybe the gauge is playing up. Cheaper to replace that on spec than change the head gasket. I wouldn't expect the head gasket if it isn't losing water but it may be worth getting the coolant sniff tested for combustion gasses.
Old Aug 15, 2012 | 06:19 PM
Brendan's Avatar
Brendan
struggling with reality
silly question have you done anything to affect air flow through the engine bay? also have you checked the fan comes on?
It could be a blockage some where! So have you deliberately opened up the water system by disconnecting a pipe to see if you get water flowing / pissing out at the TOP of the engine?
Old Aug 15, 2012 | 06:45 PM
Tailor1's Avatar
Tailor1
done all that mate - mechanic said its all flowing , opened it up and it poured out - 3 weeks trying to sort this out had another mechanic say it was the rad , one says Rad and the other says dashboard
Old Aug 15, 2012 | 06:47 PM
flannigan's Avatar
flannigan
Plug it in with a diagnostic machine and monitor coolant temp whils driving on motorway / dual carriageway and you will have an accurate temp reading
Old Aug 23, 2012 | 03:15 PM
0150carmac's Avatar
0150carmac
Hi buddy i had this same problem with a rover that was in for repair it ticked over all day never overheated then when you drove it along the road it would overheat a traced it down to a new thermostat had been fitted the wrong way round turned it round and all was ok hope this is of some help to you
Old Oct 21, 2012 | 07:10 AM
swain78's Avatar
swain78
Had this problem on mine recently. Mine was caused by a leaky water pipe. Wasnt allowin water out but was sucking air in. I managed to get whole set of pipes from a 04 focus with 40k on clock flushed the system through. Inc heater matrix as kept goin cold and not had any probs since.
Hope this helps
Old Oct 23, 2012 | 03:55 PM
Stewart Bell's Avatar
Stewart Bell
i am having the exact same problems . while driving at speed my temp gauge goes up and fans stay on its driving me crazy too . so far i have replaced water pump thermostat radiator coolant cap all with no success the last thing i have to do is cht sensor and im praying it helps but no banking on it . i am also not loosing coolant and had a pressure test the results were 190 psi on cylinder 1-3 and 180 on cylinder 4 so i am not convinced it is head gasket a few suggestions that have been made to me are bottom radiator hose getting vacumed at speed and possible catalytic converter issues i was hoping you may have solved yours and had an answer lol
my car is also a 1.8 2001 zetec
Old Oct 23, 2012 | 04:01 PM
Stewart Bell
i forgot to add my temp fix was to remove the thermostat and its fine n just cold and not so fuel efficient
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
