Pinto valve springs
Old Aug 11, 2012 | 08:29 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Default Pinto valve springs
Hey fellas , my friend has just had an new engine built up for his mk1 . Its now a 2.1 with a newman cam and solid tappets etc . He chose not to take my advise and buy some uprated valve springs and now we are having a problem with the standard springs fully compressing causing the engine to lock and the belt to jump teeth .
Can anyone advise me as to which are the best uprated valve springs to go for ?
Old Aug 11, 2012 | 08:39 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
A critical measurement you need to do is the valve spring with valve fully closed.
36mm is the "fitted" length of the spring
If its too tight you need to machine the head to allow the spring to increase its length
I made a tool to do this exact job when I build Pinto engines
Kent Cams twin valve springs are uneven length but I do not use Pinto valve springs I use a pair of matched length valve springs and the tool I made allows the valve guide support to remain in place but the head around the guide is able to be machined
(Hope this makes sense)
Took 2 days on a spark eroder to make the tool
Yes I know it is an inaccurate "Coast Down" Rolling Road BUT as I always use the same rollers I am able to make usefull comparisons and it works for me !
Old Aug 11, 2012 | 08:50 PM
Roscopeco's Avatar
Roscopeco
Thanks for the advice , seems funny why you've had to do that ?Id of thought with the right springs for the cam you shouldn't need to do that ?
Ive just been lookig on the newman info page and found that with the phase 4 cam theres 2 choice of spring . Doubles or singles , id of thought doubles but why have singles listed aswell ?
http://www.newman-cams.com/pdf/ford.pdf
PS good power from your pinto what spec is it ?
Old Aug 11, 2012 | 09:04 PM
RS2000CUSTOM
Have a read of this PDF - very usefull
How to tune a Ford SOHC
I have been constantly developing my engine for over 8 years but it is "basically" a 2143cc 8 valve
As an idea of the level of work I have carried out here is the inlet ports latest reworking
Old Aug 11, 2012 | 09:12 PM
Roscopeco's Avatar
Roscopeco
Wow thats some serious port work . Thanks for the link i'll have a read up and email it to my mate
What carbs are you using ?
Old Aug 11, 2012 | 09:18 PM
RS2000CUSTOM
Currently a pair of "machined" Weber 45's but soon to be on these bad boys !
Currently fitting a dry sump set up to protect the crank !
Heres the crank
Old Aug 11, 2012 | 09:21 PM
RS2000CUSTOM
Heres an earlier pic of the engine bay
Old Aug 11, 2012 | 09:22 PM
Roscopeco's Avatar
Roscopeco
Omg i nearly had an accident in my trousers looking at those pics . Thats some seriously nice metal you've got going on there . Would you part with the 45's when you fit the throttle bodies ?
Old Aug 11, 2012 | 09:29 PM
RS2000CUSTOM
Try not to get your keyboard sticky lol
Sorry but am keeping the carbs to go on a screamer of a 1600 ohv I am also building
Old Aug 11, 2012 | 09:31 PM
Roscopeco's Avatar
Roscopeco
No worries fella they would have been perfect for the i4 weve got waiting for the other project
Old Aug 12, 2012 | 01:25 AM
tjRS500's Avatar
tjRS500
What will be the spec of the 1600? Very interested, that engine bay looks fantastic aswell
Old Aug 12, 2012 | 10:18 AM
RS2000CUSTOM
The 1600 will be "Historic Spec" legal so mods are limited
The key to power is the compression ratio and how the engine is put together
The engine will be going into an historic spec MKII escort rally car
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
