IMRC Missing?!
Old Aug 11, 2012 | 02:00 PM
Matt_16v's Avatar
Matt_16v
Default IMRC Missing?!
So, my ST200 had started coughing and spluttering recently and having read up a bit on this i thought the imrc was probably at fault. Decided to investigate today so whipped the bonnet up, removed the plastic cover and found...its missing!! And i dont mean disconnected, i mean theres a big hole where the thing should be! What the hell is going on? I do have another as it happens but, typically, i cut the cable to get it off the other car thinking, foolishly as it turns out, that id have one of those!!
Any ideas?? Why would someone remove this and how is it even really runing without this?
Old Aug 11, 2012 | 04:06 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
IMRC? Not everyone knows what that mate?
Old Aug 11, 2012 | 04:22 PM
pani_k's Avatar
pani_k
PassionFORD Member
Inlet Manifold Runner Control
I would've thought that it not being present would be bringing up the EML light unless it has been removed and the car is running only a standard manifold and been remapped to run this but really strange as to why.
Old Aug 11, 2012 | 04:26 PM
trek's Avatar
trek
Are you sure its missing and not just relocated. Its quite popular to move the unit to under the battery tray to reduce the influence of heat from the engine.
Old Aug 11, 2012 | 04:46 PM
Csm's Avatar
Csm
Its surely just re located ??
Controls the secondries opening up for the power kick you should feel under hard throttle.
Old Aug 11, 2012 | 04:59 PM
Matt_16v's Avatar
Matt_16v
Ahhhh my god, such a good point! I hadn't thought about it being relocated, what a douche! With have a poke around tomorrow and report back, but yes I'm sure that's it. Cheers chaps.
Old Aug 11, 2012 | 09:12 PM
Bungle's Avatar
Bungle
That's exactly where I've moved mine to
Old Aug 14, 2012 | 07:57 PM
James's Avatar
James
yeah and me.
Old Aug 14, 2012 | 08:41 PM
Matt_16v's Avatar
Matt_16v
Are we talking literally underneath the battery tray, so I'd need to get under the car to see it?
Old Aug 14, 2012 | 08:45 PM
Bungle's Avatar
Bungle
Yes and no follow the cable from the throttle body one is throttle cable other is imrc cable
Mines stopped workin now :-( its been better since I moved it but when the car is hot it acts up
Old Aug 14, 2012 | 08:46 PM
liam-rst's Avatar
liam-rst
shit happens
Yeah usually under the battery, that's where mine was located to, look for a cable on the back of the inlet on the right hand side and find a long black cable and follow it you should find a silver box approx 100mm x 100mm an that will be your imrc
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
