Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
gas welders
Old Aug 11, 2012 | 08:04 AM
boaby's Avatar
boaby
Miester
Default gas welders
whats a decent size ampage for welding car panels ect, im not gona be fabricating iron gates or shit just the odd bit on the car.
Old Aug 12, 2012 | 12:28 PM
saph_Al's Avatar
saph_Al
Have a looky at the Clarke turbo range , I have a 180amp (i think ) for use out and and about and it's great , Ive welded upto about 3-4mm without any hassle. Only down side is the torch is fixed to the unit so if i need to change it i could have a issue ,
Old Aug 14, 2012 | 07:39 PM
homer j's Avatar
homer j
130Amp is the minimum really for a MIG welder doing automotive work. that should be able to cope with most stuff and panel work will be a doddle. i have a sip 170amp mig machine and that does 6mm thick steel with ease.
Brian
Sep 11, 2015 08:06 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
gavt123
Sep 5, 2015 10:03 AM
