Hard pedal but no stopping
Hi,
you may be aware I'm trying to recommision my Granada and hopefully get an MOT on it too.
Have been running it fine where it has sat (for 6 years). I have done loads of work and slowly, finally getting there. Turned it around today and realised that my excellent brake pedal didn't = excellent brakes
good job it was a 3 point turn on my drive.
I have a bias pedal box fitted (no servo) with 335 discs and Monster 4 pots. On the rear I have Cossie 4x4 set up.
I went to this set up as I was cooking standard stuff. This car was a dedicated track car and so chose this direction. I can now recall that the braking effort was always greater than it used to be but once I got heat into the brakes then I could manage.
Now, for a road car this is not acceptable. I have had all 4 corners off the car to check over brakes, bearings and suspension etc and all is good with nothing siezed.
What is a hard pedal and no stopping indicative of? Any ideas maybe from the mk1 / 2 Escort fraternity as they run bias boxes.
I am tempted to go Cossie pump (non ABS) but would like to retain what I have.
I have a .700 front cylinder and a .625 cylinder for the rears. I am running Mintex race pads front and green stuff rears all with braided lines throughout feeding Castrol SRF to the 4 corners.
What say you?
good job it was a 3 point turn on my drive.I have a bias pedal box fitted (no servo) with 335 discs and Monster 4 pots. On the rear I have Cossie 4x4 set up.
What say you?
Lol, its a mk 2 Granada with a Cossie in it.
No servo and I replicated what was comonly used on other cars with not too disimilar set ups. If it had a sevo and I had the issue I would deffo say its poor assistance. That said I am on a bias set up and should be completely capable of what I need.
Might have to look at the bias bar for bind etc.
I remember this when I first did the conversion I was worried about it but I did loads of track days and never once had an issue of not stopping - I need to get brave lol.
I had the same problem on my mk1 escort with pretty much the same spec as you, i installed a remote servo and it cured the problem.
Burton power told me that the .625 were for the front and .700 for the rear, I don't know if that's correct or not now
With the right sized cylinders non servo brakes should work fine if all in order, i do know from experience that the wrong bore cylinder causes major problems with pedal effort as I used to run a mini with front discs and never changed the master cylinder was a massive difference when I fitted the correct one.before trying to fit a servo take some advice from a brake specialist regards cylinder bore choice.
I would like some improvement but I don't want to be at the stage of having to swap out MC's 'just to see' etc. The fronts were a pig to bleed lol.
take a calliper of the disk & support with a piece of wire and pump the peddle ... should see movement! if not it could be seized. try to rotate a bit to free off. try each side at front to start!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
sridgett
Oct 1, 2015 07:30 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
