Silvertop zetec head gasket?
Old Aug 5, 2012 | 02:36 PM
mikey_clough's Avatar
mikey_clough
Default Silvertop zetec head gasket?
Hi all, I'm currently in the process of building a 2.0 silvertop zetec with bike carbs and looking at head gasket options.
I don't fancy using the standard fibre type gasket, question is do the blacktop steel gaskets fit? Don't want to lower the compression ratio though which I assume focus Rs gaskets do?
Old Aug 5, 2012 | 02:42 PM
crazycage's Avatar
crazycage
the standard silvertop gasket is 1.8mm thick and yes the blacktop will fit and its only 0.6mm so will raise the compression
Old Aug 5, 2012 | 03:01 PM
mikey_clough
That's good to know, I don't need any other mods to fit them do I? Can I still use the standard ford head bolts?
Old Aug 5, 2012 | 03:05 PM
crazycage's Avatar
crazycage
straight fit and the head bolts are fine , both good for over 500hp.
Old Aug 5, 2012 | 03:14 PM
mikey_clough
Thanks for the help bud!
Old Aug 5, 2012 | 03:25 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
St170 gasket is thicker than blacktop ones, iirc you can get them from ford for under Ł40
Old Aug 5, 2012 | 04:37 PM
crazycage's Avatar
crazycage
st170 gasket is 1.0mm compressed, you can also get a 1.8mm mls gasket from fords.
Old Aug 6, 2012 | 12:49 AM
Mister G's Avatar
Mister G
I'm running the standard Zetec Blacktop gasket in mine with no probs, seemed a bargain as it's MLS as standard....
Old Aug 6, 2012 | 12:51 PM
Turbo Zetec
Engine Machinist
Any idea on the part number and price?
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Chopshop85
Sep 18, 2015 06:13 AM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
