Cosworth rear beam bush removal...if I wana use again?
Hi all, read a few times about cutting the top off them and pushing um through, but what if I want to keep them?
Can they be pressed out? or a puller maybe?
Cheers lads/lassies
Cheers lads/lassies
ive seen the beam unbolted lowered away from chasis a little . round bit of wood put on top of bush with a little fairy liquid then jack the beam up so it pushes the bush out..
id just chop them out though..
cheers lads, I'll get them pressed then as the rear ends all stripped out. Don't wana cut um cause could do without paying out Ł80 for another set of new poly ones
cut the old ones out and put these in, nice and cheap I have had no problem with them and they come in two parts so are a lot easier to fit, these are the stronger 80 shore ones but they do a softer version.
hope the eBay link works
http://www.ebay.co.uk/itm/SIERRA-ESC...item3a7361fd34
Oct 9, 2015 07:38 PM
155lee
Sep 14, 2015 07:37 PM
155lee
Aug 14, 2015 11:21 AM
