rs1600i vs xr3i
Old Aug 3, 2012 | 09:00 PM
mgtkr1's Avatar
mgtkr1
Default rs1600i vs xr3i
what are the engine differences between the rs16i and the 3i. thinking about building a n/a cvh track car and wondering how well the 3i engine responds to tuning compared to the rs. im aware the rs is worth a small fortune so buying one as a track slag is unreal;istic but can a cvh be built to a similar spec without a btcc budget?
Old Aug 3, 2012 | 09:06 PM
It's Czech Mate's Avatar
It's Czech Mate
Different shaped valve throats in the head
Solid lifters
Different profile cam shaft
3i has dizzy, 16i has a mapped spark signalled via the sensor lead and flywheel sensor
Better exhaust manifold
Old Aug 3, 2012 | 09:09 PM
It's Czech Mate
if starting from scratch you might as well take a normal 1.6 cvh and mod that
Headwork will have to be done and that will remove the intrinsic value of the 16i head anyway
Check this out
http://www.gomog.com/allmorgan/cvh.html
Old Aug 3, 2012 | 09:13 PM
It's Czech Mate
Much better off installing a 1.8/2.0 zetec ( or a 2.0 duratec ) in a mk3/4 and tuning that, much easier and better\cheaper rewards
Old Aug 3, 2012 | 09:18 PM
Karl's Avatar
Karl
Norris Motorsport
There's nothing better about a RS1600i head to any 1600 cvh head of that period.
In all fairness, there's nothing trick or worthwhile about the RS1600i engine whatsoever that should encourage you to start with that engine. It is for all intents and purposes a std 1600cvh with a solid lifter cam fitted. (Yes I know it has unique anciliaries but they're only special if you're keeping the RS1600i car as an original car)
My recommendation is get yourself a late XR3i hemi engine (i.e. 86 - 89) and modify that. Usual route would be big valve ported head, solid lifter cam, set of throttle bodies, decent 4/1 exhaust manifold, H section con-rods, set of forged pistons and around 12:1 C.R. Good for 160bhp. Happy days!
Old Aug 3, 2012 | 09:25 PM
It's Czech Mate
so the round fluted exhaust ports are of no benefit to the standard more 'tunnel shaped' xr3i ones?
(obviously if having head worked then not an issue but as standard the 16i head IS better)
Off topic, can we have some pics and an update on your gorgeous 3 door?
Old Aug 3, 2012 | 09:34 PM
Karl's Avatar
Karl
Norris Motorsport
No there is no benefit whatsoever to the slight machine work done on the exhaust port exit. Firstly it is only the very exit that has had a circular taper on it to essentially diverge the D shaped port into a circular exit, the throat and seat area are std cvh in profile. This machining op was done to all CVH engines in that period that used a round exhaust manifold port, not just the RS1600i. It is however of no benefit to power whatsoever.
Old Aug 3, 2012 | 09:45 PM
mgtkr1's Avatar
mgtkr1
i had a feeling internally they'd be little in it, been that the cvh is somewhat generic. just thought been an rs it would have some clever porting/hot cam and larger valves ect since its qouted hp is reasonable for an n/a cvh. the brooklyn car footage on pootube got me thinking, they sound kin ace.
stephenb4506
33
Oct 2, 2015 06:25 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
