Timing
Old Aug 3, 2012 | 02:31 PM
Jasoncmor's Avatar
Jasoncmor
Default Timing
Hi all.
Before anyone says anything, I locked the cams and flyhwheel / crank before doing this job.
I changed the cambelt, didnt have any problems apart from when I was locking the cams.
I locked the crank at TDC, and the inlet cam was flat parallel to the top of the cylinder head, but the exhaust cam was off, it was off by about 2-3mm.
Is this correct, or did the old belt stretch slightly and mess the timing up?
I had no running problems, only a rough idle, which dissapeared as soon as I touched the throttle.
Cheers, Jason
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
