How does a saph cossie front bumper attach to the car?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
There should be a bracket either side mate which locates into a plastic clip on the lower part of the wing, you can buy replacement brackets from one of the traders on here but they aren't cheap!
yeah beats me wht they dont bolt up like a three door one and just rely on the sides to hold too easy to get nicked!!! where they push in i put a self tapper through mine as a safe guard
just remove the headlights and drill a hole through the chassis and bumper adjuster bars and sccrew into them
thats what was done when i got the front bumper painted but as the wipers attach to the lights i couldn get the lights in after it was all screwed down that way
can the wipers be fitted after lights an bumper?
Yes mate, it's a bit of a fiddle but you can do it
mine slots into the hanger and has a 13mm bolt that goes into it
what i do is peel back the bumper insert, and drill behind the insert into the wing where the blackplastic clips go in, then just use a larg self tapper screw and put the bumper insert back in
