2wd Cosworth Crank, rods and other bits and bobs PICS ADDED
Old Aug 1, 2012 | 11:14 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Default 2wd Cosworth Crank, rods and other bits and bobs PICS ADDED
I'm having a clear out and open to sensible offers or trade as I need a few things for the p100 cossy. I can post the smaller stuff but blocks etc will need to be collected.
Cosworth Stuff
2wd Cosworth Crank Std Journals but has spun a shell on number 4 .25 re-grind should be fine. £offers
205 blocks all on std bore but with ware with/without caps, no signs of cranks £75 - £100 each
Set of 3 std rods (or 4 if you want the damaged one) £offers SOLD
Couple of jack shafts and pulleys
2wd Plenum £75
Upper and lower adjustable steering column inc switches, storks and barrel £50
Non Cosworth Stuff
MT75 Gearbox mount and cradle £15
MT75 Gearbox short prop £10
P100 loom ( has the rear lights cut off) £offers
Mk1 Sierra V6 Ghia loom ( has the rear lights cut off) £offers
P100 Front Hubs £30
P100/ERST Front calipers £30
205 Block 2.0ltr pinto N/A £offers
Type 9 5speed box and bell housing to mate to pinto £75
3.92 open 7.5" diff with lobro flanges £40
Sierra GLSI rear barring carriers for disc brakes £10
Sierra Sapphire Scuttle £10
Sierra Master Cylnider NON ABS - £10 each
Sierra Expantion/Header Tank - £10
Note the pinto engine and box is still in my p100 but will be coming out this weekend.
Wanted
2wd ABS Servo / Master / pump etc
2wd Cosworth Header Tank in good condition
2wd Cosworth Alloy Rad
RS500 style Intercooler
L6 ECU
Set of 803's
Old Aug 1, 2012 | 03:19 PM
Mr C's Avatar
Mr C
3.9ratio 7.5"diff can you forward me your details, where abouts are you in the UK, PM me your details re location and payment
Old Aug 1, 2012 | 06:39 PM
M K's Avatar
M K
edited
Old Aug 1, 2012 | 06:44 PM
flannigan's Avatar
flannigan
can you tell me what markings the rods have on the caps please L S or H ?
Old Aug 1, 2012 | 06:46 PM
DixieTheKid
Pick-up P100 Power!
Just checked and mine is different to that, its off of a 2wd GLSI. Sorry bud.
Old Aug 1, 2012 | 06:49 PM
DixieTheKid
Pick-up P100 Power!
They have H on them, i've come across this before. What is the difference anyway?
Old Aug 1, 2012 | 06:53 PM
flannigan's Avatar
flannigan
its the weight of the rod mate l = light s = standard h = heavy but they all measure exactly the same size but there is 30g diffrence in weight
how does £45 delivered sound ???
Old Aug 1, 2012 | 06:58 PM
DixieTheKid
Pick-up P100 Power!
£75 and ill ship them tomorrow. £25 a rod inc postage is a steal!
Old Aug 1, 2012 | 07:00 PM
flannigan's Avatar
flannigan
are they mint condition ?
Old Aug 1, 2012 | 07:03 PM
DixieTheKid
Pick-up P100 Power!
Let me boot up my pc and ill set you some pics. PM me your email please.
Old Aug 1, 2012 | 07:06 PM
flannigan's Avatar
flannigan
you have pm
Old Aug 1, 2012 | 07:14 PM
M K's Avatar
M K
Thanks anyway
DixieTheKid
Pick-up P100 Power!
you have pm
Pics emailed
Old Aug 1, 2012 | 07:55 PM
mechanic28's Avatar
mechanic28
i have a l6 or at least pretty sure i do
Old Aug 1, 2012 | 08:06 PM
flannigan's Avatar
flannigan
bit difficult to tell in the photos but ill take them and have them checked over to make sure there strait and round mate pm me youre paypal pls
Old Aug 1, 2012 | 09:15 PM
flannigan's Avatar
flannigan
Payment sent re conrods
Old Aug 12, 2012 | 11:20 AM
DixieTheKid
Pick-up P100 Power!
Bump
Old Aug 12, 2012 | 11:38 AM
marky g's Avatar
marky g
Default Hi
Hi is the mt75 gearbox mount for a rwd one
Old Aug 12, 2012 | 11:50 AM
DixieTheKid
Pick-up P100 Power!
yep. You got it. Do you want me to put up a pic?
Old Aug 12, 2012 | 01:25 PM
marky g's Avatar
marky g
Default Hi
Iam not really fussed on seeing a pick if it's a pain. Is it 15 posted? CheeRS
Old Aug 12, 2012 | 01:48 PM
DixieTheKid
Pick-up P100 Power!
ERm.. make it £17.50 posted and ill post it tomorrow. ill PM you my PP address.
Old Aug 16, 2012 | 05:54 PM
DixieTheKid
Pick-up P100 Power!
Any interest in the crank as im now thinking about having it re-ground and putting it on ebay?
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
lockie
Jul 31, 2015 10:03 PM
