mk3 fiesta 1.8 diesel gearbox
hi my fiesta has just spat its gearbox out and just wondered if the 1.8 diesel box is stronger than my standard box, and what kind of ratios they are because ive seen one forsale
do the have more top speed ????
better acceleration ?????
thanks for ur advice
also do they go straight in ???
Try LSD if you can get a second hand one, standard ones are stronger to an extent because they havent put up with the stress of high power and are likely to last longer, given you dont constantly blast in in 1st and 2nd all the time, more power more money mate sadly
mine lasted 4 years and had plenty of stick so i reckon a standard box for say 60 quid is ace. just thought a diesel one would be more stronger ! as for lsd cant seem to find one !
I don't know about strength bit the limited info I have leads me to believe the diesel has slightly higher gears so slower acceleration and higher top end! also regarding the differential, they are interchangeable so the LSD can go in a replace a non LSD or you can get a quaife TSD these are really good! I like mine!!!
The physical box is no stronger only perhaos the main shaft. Ratios are no good for a petrol turbo though. Only common mod is to fit a lsd an the turbo1st to 4th then the diesel 5th for good economy and motorway cruising
No tougher at all. It's a myth as old as the hills that they are tougher. Would expect ratios to be pretty shitty for your petrol car as well tbh. Get a proper box with an LSD. Buy once and buy right. Just ime of course
