What does a turbo damper do?
Old Mar 4, 2005 | 03:50 PM
The Gravedigger's Avatar
The Gravedigger
Default What does a turbo damper do?
Just interested.
Old Mar 4, 2005 | 07:18 PM
Hectori's Avatar
Hectori
turbo damper reduces the strain on exhaust manifolds bolts.
turbos vibration and weight causes that strain.
you should notice too, that there are diffirent types of dampers.
Old Mar 4, 2005 | 11:12 PM
magic randy's Avatar
magic randy
could you tell us about the other types ? plz
Old Mar 5, 2005 | 05:58 PM
Hectori's Avatar
Hectori
well, there is spring type dampers, like there is in cosworth, and then there is dampers, whit uniball joints. attachment whit these dampers can wary much. there is many different designs. i think tripod type damper whit uniballs is the best. you can use multiple dampers too.
the cosworths spring type dampers are good too, when adjusted correctly.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
