is this an MOT fail ???
Old Jul 27, 2012 | 10:19 AM
capricougar's Avatar
capricougar
Default is this an MOT fail ???
A driver at the yard claims that his car failed MOT on two things,a ball joint and an air freshener on the mirror!!!! ( obstructing view).
Old Jul 27, 2012 | 10:21 AM
phil_rs's Avatar
phil_rs
yam yammer
Yes it can be a fail now, depends on the tester
Old Jul 27, 2012 | 10:42 AM
bazzal's Avatar
bazzal
When I took my Focus for an MOT I stupidly left the sat nav in the window, the tester said that he'd failed it for my sat nav obstructing my view, as soon as I took it off in front of him he passed it.
So yes, it can be a fail.
Old Jul 27, 2012 | 10:45 AM
andrewg's Avatar
andrewg
ball joint and obstruction of view defo fail has been for years
if it was only air freshener we would of took it off
but as it was needing a ball joint it was going to fail anyway
we had a guy get points against him by VOSA for passing a car with air fresheners!
Old Jul 27, 2012 | 10:50 AM
CR41G_86's Avatar
CR41G_86
1.8 zetec ka in the makin
sat nav or an air freshener ?? seriously ?? so does that mean sat navs cant be stuck to your window while on a public road?? so why do they come with glass suction cups??
mot tester must just be a jobs worth
Old Jul 27, 2012 | 10:51 AM
Brendan's Avatar
Brendan
struggling with reality
Does that mean I should take of my road tax from the front window as that is obstructing my view too?
I don't think I left in the the glove box to pass the MOT will cut it!!!! I even got pulled about 8 years ago when I had a Citroen and put in the middle of the window at the bottom (single wiper so worked better for me anyway) instead of the near side bottom corner.
this is all madness......
Old Jul 27, 2012 | 10:59 AM
andrewg's Avatar
andrewg
VOSA inspectors are the jobs worth, not mot testers
Old Jul 27, 2012 | 11:03 AM
andrewg's Avatar
andrewg
as long as its not in drivers view of the swept area!
think you are alowed 10mm chip in drvers view of swept area
but if its behind rear view mirror it can be any size, thou it may be in swept area its not in drivers view !!
Old Jul 27, 2012 | 11:12 AM
furry's Avatar
furry
DECODING JIBBA JABBA!!
a tax disc and an authorised parking permit are allowed in zone B
when they started doing the stickers on the MOT sheets to put in your windscreen they themselves where a failure if in the wrong place lol
Old Jul 27, 2012 | 11:18 AM
andrewg's Avatar
andrewg
‘Official’ stickers that are not readily removable, such as vehicle licences, parking and access permits, are only a reason for rejection if they seriously restrict the driver’s view. ‘Official’ stickers should be taken to be any sticker that is used in connection with ‘road enforcement’, ‘security’ or ‘crime prevention’ matters. These include: Disabled Persons Badges/permits, Parking Permits, Licences and Vehicle Anti-Theft Scheme stickers issued by a Police Authority.
Old Jul 27, 2012 | 11:19 AM
andrewg's Avatar
andrewg
Where items are present in the driver’s view (such as a sat nav, air freshener etc) that would justify a Reason for Rejection, the tester may, at their discretion, remove the items prior to the inspection. This fact should be noted on an Advisory Notice.
Old Jul 27, 2012 | 11:52 AM
capricougar
well ya learn something new everyday. warnings on air fresheners, thought the lad was bulls****ing too! thanx for the replys.
Old Jul 27, 2012 | 03:55 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
When testing a vehicle presented with Zone A (drivers swept view area) "stickers or obstructions" I am now (as ALL MOT testers are as well) allowed (a recent addition to test criteria) to remove (if safe to do so) objects within Zone A and there is a special Advisory item I can select to show I have done this.
The end result being that the owner/presenter does not have to be messed around being asked to remove items after test and then have a retest.
Common sense prevails whilst I carry out any MOT
Old Jul 27, 2012 | 04:01 PM
RS2000CUSTOM
Found the section
Originally Posted by MOT Testers Guide
Section 8 – Driver’s View of the Road
Testers are now permitted to remove items from the driver’s view that would lead to rejection at their own discretion.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
