Newbie Alert
Hi All,
Recently purchased a St170 so far am over the moon with it. Even though i have already had EML on
but a code reset and a change to Higher octane fuel seems to have helped for now but im sure it will come back.
Ad
but a code reset and a change to Higher octane fuel seems to have helped for now but im sure it will come back.Ad
thankyou, i a bit new to all this forum stuff so please bare with me, I have an issue with my 58 plate 1.6 focus it shows the esp light permently illuminated, I have had it put on a computer and the code C1288 comes up saying pressure transducer main/primary circuit failure. This has been reset but comes straight back on . I have been told that it may be the ABS ECU modulator at a cost of £1300 supply + fitting.
the plugs to the ABS and steering look ok si im wondering if you or any of your members have any thoughts or wisdom to share. Thanks in advanced Chief
Feb 14, 2004 03:23 PM
