Airco pump and steering pump
The aircopump off my escos is starting to make some noise and also is my steeringpump. Does anybody know where you can rebuild them?
depends what the noise is on the air con compresssor (it's not a pump). if it's just the bearing in the pulley then they can often be replaced.
i'm struggling to remember any big aftermarket a/c companies in belgium or NL
