s2 radio wiring diagrame
Old Mar 4, 2005 | 12:41 PM
Robin's Avatar
Robin
Default s2 radio wiring diagrame
can some 1 post a pic up for me for the radio wireing?? my s2 came with the ford eq and i can't wire up my headunit as the loom is pretty much non exsitent. or could u tell me which wires do what. cheers
Old Mar 4, 2005 | 04:38 PM
rich2302's Avatar
rich2302
To wire up your head unit you will need the following.
Perm 12v (red)
earth (brown or black)
switched 12v (yellow)
You should be able to locate the original stereo plug and this should have all 3 wires you need, if not then get in there with a multimeter and find them.
As far as the speaker wires go, pull all 8 wires up so you can reach them and then using a charged aaa type battery put one wire on the bottom of the battery and then try all the other wires in turn on the top of the battery until you here some white noise and you will have a matched pair, continue with the other 6 that are left until you have all 4 speaker wires matched and then hook them up to your speaker wires and you will be sorted.
Need any more help then give me a shout on 07730 530765
cheers
Rich
Old Mar 4, 2005 | 05:20 PM
Robin's Avatar
Robin
cheers rich, not worried about the speakers as there all going to be amp run
Old Mar 4, 2005 | 06:32 PM
bassboy's Avatar
bassboy
hi robin, if i was you i would run a fresh cable to the battery for your positive live (the current one will be pretty resistive by now) and then undo the ignition barral cover bit and locate a switched live and run that to the red lead on the headunit. Then for your earthing point, if you take off the gear leave surround bit (the big plastic panel where i think your EQ will be sitting), there will be a bolt there you can undo and use as an earthing point and works VERY well...
bit of a long way but atleast you will know the power supply to the headunit will be solid
bassboy
Old Mar 4, 2005 | 06:48 PM
AKRS1's Avatar
AKRS1
There should also be like a grey one which dims the headunit when the lights are on
Old Mar 4, 2005 | 07:22 PM
Robin's Avatar
Robin
cheers guys am really tempted to pay some 1 to fit it for me
Old Mar 5, 2005 | 08:34 AM
SS1's Avatar
SS1
glad you got the help you needed standard ford radio loom
conections ie plugs seem to be PICS information "scarce"
on this site
pondering why
ive now got the full audio wire colours lists for a saph
but got no help from here
post costs nothing on here
Old Mar 5, 2005 | 08:38 AM
bassboy's Avatar
bassboy
im in west london if you wanna pop down robin
bassboy
Old Mar 5, 2005 | 09:12 AM
Robin's Avatar
Robin
bassboy
sounds good mate add me to msn and we can chat cosworth_440@hotmail.com
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
THE RADMAN
Sep 19, 2015 12:57 PM
