transit connect 56 factory lpg
decided to sell my connect it is a rare factory 1.8 zetec lpg conversion
on a 56 reg bought this to use as a runaround with the intention of converting it to frs but sick of looking for a damaged focus rs so decided to sell.
very economical with gas only 71p a litre im averaging 85 miles to £10 around the doors £32 fills it up !
surprisingly good on petrol to,has full removable bulkhead fitted and is fully carpeted out in the back which is very clean,also has nokia bluetooth hands free kit fitted
as you can see by the pics the lpg tank is fitted where spare wheel would be underneath, and the spare wheel is now on a bracket inside the rear above wheel arch.
very clean although there are a few little dents etc as to be expected from a van but is not a battered builders van as you can see on pics
t&t , just turned 90k miles spare keys and fob,handbooks etc
this is a factory conversion so done properly with hardened valves etc gas and petrol both on the same gauge and has a manual switch if you want to run on one or the other.
drives perfect with plenty of power on either fuel,no knocks or bangs etc
£2400 or sell me your damaged frs lol
some 1 has a complete cobversion on fiesta turbo matey
http://www.fiestaturbo.com/forums/fo...sion-vt195037/
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
